Home > In Car Electronics > Any suggestions appreciated
geoffsnook
The op does say he has no flashing lights/warning lights so no codes will be stored if i am correct Thumbs Up
Post #535179 Wed Sep 13 2017 10:05am
Paddi
Apart from "vehicle fault shutting down" as mentioned by the OP.
Many faults are stored without any warning lights or messages being displayed. 2008 MY Java Black TDV8 HSE
Post #535187 Wed Sep 13 2017 10:38am
geoffsnook
But it does not shut down and goes back to normal after a bit so would suggest either a battery but op has tested it or a loose connection some where which would come up with a u code lost comms with what ever Shocked
Post #535188 Wed Sep 13 2017 10:47am
iannixon
Have ordered a new battery and also booked in on Monday for mot..service and to check fault codes.Hopefully will be able to get to the bottom of it. Thanks for all advice. Will post when they find out the problem.
Post #535365 Thu Sep 14 2017 5:37pm
iannixon
Finally got sorted...it was the instrument cluster causing all the problems. Took so long because warrenty wanted the garage to go through lots of hoops before they would order new cluster. My thanks to Jagtechnic of Eastbourne for their perserverance and patience. Very Happy
Post #539491 Sat Oct 28 2017 8:50am
