Home > In Car Electronics > Dipped Beam Bulb Type |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4788 |
valeo and LR should be the same thing.
Tue Sep 12 2017 6:15pm |
azz Member Since: 09 Dec 2014 Location: Worcestershire Posts: 73 |
2010 facelift headlights use the D3S. Earlier cars used the D2S. I had exactly the same issue recently. 2010 RRS 3.0 TDV6 - Bali Blue / Ivory Leather / Extended Leather / TV / Rear Entertainment / Privacy Glass / Timed Climate
Tue Sep 12 2017 7:26pm |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 |
Spot on Azz
Tue Sep 12 2017 7:29pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8841 |
The bulb type is shown on the headlight itself. There is a moulded-in panel on the top surface with info about the lights, who make them, E- numbers etc. It should have the xenon bulb on there too. On mine, it's at the outer end of the panel. Just visible here at the far right - it's easier to read on the real thing. This is an OEM Hella unit (hence the scrubbed out LR logo!)
RRSTDV8 - Well I never knew that Will check it tomorrow when I'm off to work as I'm too lazy to go to the garage now
Tue Sep 12 2017 7:33pm |
I just went out in the rain to take that snap! 2012 SDV6 - it's missing a couple of cylinders
Tue Sep 12 2017 7:36pm |
Tue Sep 12 2017 7:39pm |
Thanks for all the help got it sorted.
Mon Sep 18 2017 10:37am |
I think fog lights, light up the road quite well, depending how far your going and if you know the route well |
Mon Sep 18 2017 12:15pm |
Andy K,
Mon Sep 18 2017 12:18pm |
