Home > In Car Electronics > Any suggestions appreciated
iannixon
Couple of times over the last few days while I have been driving a message has come onto my radio screen saying "vehicle fault shutting down". The radio goes off..then the temperature controls...then the sat nav and finally I lose digital display from the dash but the speedo rev counter fuel and water temp gauges all keep working. I think my hazard lights come on as well. After about 1 min it all restores to normal. Any help would be appreciated.
Post #535029 Mon Sep 11 2017 6:24pm
geoffsnook
do you have codes at all or yellow warning lights at the time it starts or a red battery warning light Thumbs Up
Post #535031 Mon Sep 11 2017 7:00pm
iannixon
nothing....no flashing lights it all just goes dark.
Post #535032 Mon Sep 11 2017 7:04pm
geoffsnook
How old is the battery Thumbs Up
Post #535034 Mon Sep 11 2017 7:10pm
iannixon
TBH not sure...ive had her for 1 year and always seems to be plenty oomph to get her started.
Post #535035 Mon Sep 11 2017 7:14pm
geoffsnook
Can you test it at all with a multi meter across battery terminals with engine running and engine off Thumbs Up
Post #535039 Mon Sep 11 2017 7:39pm
iannixon
Will try after work tomorrow...what sort of voltage do you think I should expect to see?
Post #535045 Mon Sep 11 2017 8:38pm
geoffsnook
Over 12 volts with engine off and over 14 with engine running Thumbs Up
Post #535049 Mon Sep 11 2017 9:02pm
phillh
United Kingdom 2005 Range Rover Sport TDV6 HSE Zermatt Silver
I bought one of these when I was concerned about my alternator, found it very useful.
http://www.ebay.co.uk/itm/Large-LED-Digita...SwCkZZVkaJ
Post #535056 Mon Sep 11 2017 10:10pm
iannixon
Have checked the battery and alternator (mate lent me a battery analyser) the results I got were
battery. 12.3
no load. 14.16
loaded. 14.3
The analyser said all ok. In the middle of the test it happened again so I switched off engine. I got a message saying
"park brake fault and "hdc fault. system not available". The car wouldn't start. By releasing and reapplying handbrake I could hear a motor running. This sounds like it could be expensive. Big Cry
Post #535112 Tue Sep 12 2017 6:21pm
geoffsnook
Battery seems not to bad i have heard on here about some loose connections to the rear of the instrument panel and it may be worth you checking the rear of the radio to make sure everything is plugged in correctly the noise you heard is the motor for winding in and out the hand brake shoes Thumbs Up
Post #535126 Tue Sep 12 2017 7:29pm
iannixon
How hard is it to get to back of radio.
Post #535128 Tue Sep 12 2017 7:34pm
iannixon
Would it be worth getting new battery anyway?
Post #535129 Tue Sep 12 2017 7:35pm
geoffsnook
Search on here radio removal not to hard to get out Thumbs Up
Post #535136 Tue Sep 12 2017 8:36pm
Paddi
Before pulling the dash apart would it not be wise to read the fault codes using a tool capable of reading land rover faults not just generics?
Also check the battery connections and earths for tightness and good contact. 2008 MY Java Black TDV8 HSE
Post #535165 Wed Sep 13 2017 9:35am
