Home > Technical > Webasto Software |
RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280 |
That shows laptop is connected to FBH with no faults logged
Sun Apr 23 2017 10:30pm |
Wayneclarke Member Since: 16 Jun 2014 Location: kent Posts: 394 |
Thanks for the reply Rob, maybe a stupid question but does the engine need to be running or can the FBH be triggered without and just by the laptop |
Mon Apr 24 2017 7:08am |
Not a stupid question at all.
Mon Apr 24 2017 9:54am |
Brilliant cheers for the information Rob I will give it another go |
Mon Apr 24 2017 10:04am |
Mon Apr 24 2017 9:00pm |
Brilliant thanks for the information will let you know how it goes. |
Tue Apr 25 2017 3:36am |
hi, sorry I never replied before I'm just looking back at my post as I'm going to give the software another try soon , as the cold weather is slowly creeping up. The problem I have is the fbh works for a while then just stops for no reason ? Last time I couldn't run the fbh wasn't sure if the ignition needed to be on |
Mon Sep 04 2017 9:14pm |
Usually it's because there's not enough airflow, so starts to fire up, then goes into cooldown mode. I've taken quite a few of these apart for that issue and it's just a case of cleaning out the burn chamber. Bodsys Brake Bible
Tue Sep 05 2017 12:27am |
