Home > In Car Electronics > Fitting a Pioneer car play double din unit
R1CHD
United Kingdom 2005 Range Rover Sport TDV6 SE Java Black
Good Morning,
I bought a 2005 SE sport yesterday It has the standard head unit fitted with no phone connection/Bluetooth and also no sat nav/info screen but the door speakers have Harmen Karden on them. I would like to replace the existing head unit with maybe a Pioneer app unit with apple CarPlay but just wondered what conversion kit is required I've had a look on YouTube and look like a simple task to replace but I just don't understand the difference in systems i.e. Harmen Karden, logic 7 etc, any help would be great
Post #533886 Sun Aug 27 2017 7:46am
you won't have logic 7
but if you move the drivers seat all the way forward, and have a look under the back of it, you will probably find an amop in the floor
(metal fins and row of connectors, lots of green wires on one)
This means you will need a specific kit and someone else can advise
Post #533893 Sun Aug 27 2017 10:29am
R1CHD
Hi Andy
Thanks for the replay I do have the amplifier under the drivers seat looking around I have found a kit on EBay that appears to solve the problem item number eBay Item No. 382053062365 has any one fitted this kit and does it work?
Post #533959 Mon Aug 28 2017 1:49pm
yes that looks like the one suitable for your car.
But have a look on here for what others have used / recommend
Post #533962 Mon Aug 28 2017 2:39pm
geoffsnook
Not many se equipped cars with no sat nav fitted Thumbs Up
Post #533970 Mon Aug 28 2017 6:07pm
R1CHD
I'm not sure if it's a good thing or bad thing to be honest are the sat nav & 4x4 information etc much use?
Post #533971 Mon Aug 28 2017 6:13pm
Sat Nav isn't much use.
Post #533982 Mon Aug 28 2017 8:12pm
RobP
If no sat nav screen then that is correct kit for HK install
If you want to retain the sub in boot then you will need to connect an another amp from sub out on head unit to the pink leads in the green plug TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten
Post #533988 Mon Aug 28 2017 9:23pm
d-9
What's the difference between that kit and one for a car with sat nav?
Post #533993 Mon Aug 28 2017 10:20pm
RobP
The difference is the screen retention cable which is in this kit
https://incartec.co.uk/Pages/Product.aspx?P=4873
Also means you need to relocate old head unit TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten
Post #534008 Tue Aug 29 2017 11:11am
R1CHD
I tried to fit the kit today with the Pioneer SPH-DA120 head unit but the plugs don't match up and instruction are vague here's a picture of the 2 plugs I can't connect and the back of my old head unit, any help would be great
Post #534545 Mon Sep 04 2017 9:08pm
2 orange is optical network. Is that the car or adaptor end?
Other connector isn't very important.
You normally need to get an ignition supply from the cigar lighter to turn on the new head unit
Post #534548 Mon Sep 04 2017 9:51pm
R1CHD
The plugs you see me holding are the vehicle looms, the plug to the right is the car look to the new adaptor that plug in to the head unit loom, so do I just ignore the 2 other plugs and just take a feed from the cig lighter?
Post #534552 Mon Sep 04 2017 10:06pm
If the rest of the car works without the orange ones looped then that is fine.
Otherwise you will need a loop cable. Thought I saw one in the kit.
Yeah ignore the other plug.
Post #534557 Mon Sep 04 2017 10:21pm
R1CHD
Right the head unit is in and fitted thanks for the advice, the only issue I'm having is with the aerial I have really poor reception I have the Fakra Aerial cable adapter to din radio Fitted and the blue wire connected to the blue and white remote wire on the pioneer head unit but no reception I've tried connecting the blue lead to the 12v cigeretre lighter supply and the radios red and yellow power wires with no success
Post #534752 Thu Sep 07 2017 7:53pm
