Home > Other Site Sponsors > GAP Diagnostic Announcement-2016-07-25-Apple App & More |
PatGapInnov Member Since: 30 Jul 2012 Location: Montreal Posts: 42 |
I would assume you are referring to the Navigation Maps? These cannot be updated with a diagnostic tool since they are housed on the Map DVD for 2005-2009 and on the Hard Drive for 2010+ vehicles.
Thu Aug 31 2017 7:28pm |
For updating maps to your HDD you require to purchase from LR or direct from the Map suppliers. This is supplied by USB stick and you load it yourself, it takes between 2-3.5 hours normally. The cost isn't cheap, from memory think it is £189.00
Thu Aug 31 2017 7:30pm |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
Well that's my weekend taken care of In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Fri Sep 01 2017 3:41pm |
Wilson Member Since: 06 Oct 2015 Location: Ipswich Posts: 78 |
Had a good read and bit the bullet, I completed the clock in dash and also the Bluetooth flash successfully, both a lot easier than expected, I had my M3 running and hooked up to the battery just in case! Thanks for the push |
Wed Sep 06 2017 10:07pm |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1047 |
Really silly question Pat but can you use the IID tool to set the time on the dash clock?
Thu Sep 07 2017 8:32am |
Good evening all
Mon Sep 25 2017 6:28pm |
