Home > Faults & Fixes > Air suspension help needed asap issues
Revaj110u
United Kingdom 2007 Range Rover Sport 4.4 V8 HSE Zermatt Silver
Today my range rover decided to throw up a fault code for c1a20 compressor peformance not enough despite having a brand new compressor 2 months ago
First I decided with my hawke eye to deflate all the air in the system see if that would clear up any faults. It did not.
The car is now sat on its bump stops and I have just installed another new compressor hoping this would fix the fault but no nothing.
The compressor runs on start up for around 30 seconds then throws up Suspension error
I have received the from valve block to see if it was stuck or worn but it all seems great. Also removed the gallery valve block by the compressor but that seems fine also.
The one line coming from the compressor to the gallery block seems to constantly have a good amount off pressure in it is this normal ?
I'm a bit lost here as I can't hear any air leaks and all the sensors appear to be working on the hawke eye as far as I can see
Any help is much appreciated
Or last resort does anyone know a good land rover specialist in the south wales area
Thanks kris
Post #534136 Wed Aug 30 2017 9:29pm
Quote:
C1A2064
Pressure Increase
Too Slow When
Filling Reservoir
    Compressor fault
    Reservoir pipe air leak
    Reservoir air leak
    Gallery pipe air leak
    Intake filter blocked/restricted
    Intake pipe blocked/restricted
    Air suspension intake silencer blocked/restricted
    Corner valve stuck open
    Pressure sensor fault
Check the inlet air line and filter for blockages seems to be a starter.
http://www.rrsport.co.uk/gallery/albums/us...filter.pdf 2012 SDV6 - it's missing a couple of cylinders
Post #534144 Wed Aug 30 2017 10:39pm
Revaj110u
That will be the first thing I do tomorrow I think . is there anyway of disconnecting the intake at the compressor and run it to see if it is the filter or intake lines.
I hoping I find somthing
Thanks again mate
Post #534145 Wed Aug 30 2017 10:51pm
