Home > Faults & Fixes > Remote not working |
Quickest and easiest way to see if your new brake bulbs are causing the issue would be to take them out and see if you still have the same issue. |
Tue Aug 29 2017 8:04am |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 746 |
Did you use genuine LR brake bulbs? The reason I ask is that I understand these cars are very sensitive to them, and some can cause all sorts of electrical issues. I have always used gen LR bulbs for that reason, they are after all relatively cheap.
Tue Aug 29 2017 11:47am |
Plazmapete Member Since: 05 Jun 2016 Location: Cannock Posts: 118 |
No. They were brake lights from a set i got from aldi. Haven't used the car for 3 days due to working over the weekend. Today it seems to be working fine. Will have to get some genuine bulbs to replace the ones from my set just in case. Thanks. New alternator.
Tue Aug 29 2017 2:00pm |
It's been a while since I bought some, my old D3 tended not to blow them, and I seem to remember they came in packs of 2.
Tue Aug 29 2017 3:27pm |
It worked fine yesterday. Today it's playing up. Will get a couple of genuine bulbs. See if that cures it. New alternator.
Wed Aug 30 2017 9:02am |
minty77 Member Since: 05 Oct 2016 Location: Lancashire Posts: 14 |
These guys fixed my fobs for me, Did a great job and they are still working now, Give them a try
Sun Sep 03 2017 3:46pm |
I've tried to re sync the keys. Followed the procedure. Seems to work. Then if I lock and unlock the doors a couple of times it works fine. But When I come to lock the car the horn beeps at me. I have to start the car then turn it off to lock the car. New alternator.
Mon Sep 04 2017 4:19pm |
Took the circuit board out of the key to ckeck the voltage. Getting 3 volts. I can open and close the car from 15 metres away no trouble. Its when the board is in the case im having trouble. Any thoughts?? New alternator.
Sun Sep 17 2017 10:35am |
adameverett Member Since: 14 Nov 2015 Location: Warwick Posts: 110 |
Dry joint on the battery? I had a similar issue with a key intermittently would not lock/unlock. Replaced the Battery problem went away. Just a guess but key is loosing power, and you are resetting it when you reinsert/restart. I know that I had a bad contact as I use to tap the key on the ground it stated working again. |
Sun Sep 17 2017 7:41pm |
UPDATE. THINK ITS SORTED.
Sun Sep 24 2017 1:20pm |
It lasted for two weeks then went again. All bulbs are fine. Now it's an intermittent fault. Visit to garage I think. New alternator.
Sat Oct 14 2017 12:29pm |
