Home > Technical > Brake dust shields corroded
RRSNUT
2006 Range Rover Sport TDV6 HSE Java Black
Gents, Advice needed on replacing rear Brake dust shield on 2006, 2.7 TDV6 HSE
I have nasty squeal from the rear near side rear wheel, I know the dust shield on that side is badly corroded but as I was planning to upgrade the front brakes soon to brembo and clean and spray the rear calipers I have delayed getting it looked at.
Following a service I have been advised that in order to replace the rear shields the wheel bearing must be dropped off and bushes replaced so the price to replace the shield could be a good few hundred!
Can anyone help to confirm this is the case as I believe th fronts can be done with little issue so it's upsetting to hear these are a big job............and this bloody squeal is driving me nuts Big Cry
Ja Sheep North Wales Land Rover Club Member
RRS 2.7 TDV6 HSE. MY06. JAVA BLACK. FULL BLACK NAPPA
- CLEAR SIDE REPEATERS - SIDE STEPS - PARROT BLUE TOOTH PHONE - GENERAL GRABBER AT's - EGR VALVES REMOVED
Post #533314 Sun Aug 20 2017 2:56pm
what's causing the sequel ?
Is it touching the disc? bend it out the way ?
sure the caliper piston isn't stuck? is rear wheel hotter after a drive ?
Post #533318 Sun Aug 20 2017 3:28pm
RRSNUT
I have had so many issues with the rear calipers sticking/grinding I have had the rear calipers changed twice in three years, I was told it was the dust shield touching somewhere but they have told me that replacing the cover will stop the squeal, it's only light metal so not sure why they could not push it back out of the way.
Thanks mate, Ja North Wales Land Rover Club Member
Post #533319 Sun Aug 20 2017 3:34pm
maybe its the parking brake.
The parking shoes could be mounted onto the "dust cover", I can't remember.
Post #533327 Sun Aug 20 2017 4:44pm
DrRob
Perhaps get one of the mobile specialist mechanics on here to look at it? Bodsy or Woody32 are closest to you. Visitor from fullfatrr.com
* Current: 2011 4.4 TDV8 Full Fat. Amazing piece of kit.
Post #533330 Sun Aug 20 2017 5:11pm
Black Bess
You need to get that looked at by somebody sensible. Two sets of calipers in three years? I ran my L320 for 120,000 miles over 9 years and only ever replaced pads and discs (and metal brake pipes). Calipers were fine.
I don`t see why removing the backplates (if that is what you mean by dust shield) should be any more than stripping and reassembly. Not sure from memory if the parking brake shoes need to be removed. Probably do, but that is no problem either.
Post #533595 Wed Aug 23 2017 1:13pm
They do rust. And if all the parking brake stuff is mounted on it, it will need replacing sooner or later.
Calipers are a known problem. But yes, should have one required replacing onces
Post #533618 Wed Aug 23 2017 6:44pm
ShooterNeil
England 2007 Range Rover Sport TDV8 HSE Java Black
The the park break is attached to the dust/stone guards
To change the guards the wheel bearing needs pressing out that means the hub has to be removed so can Affect camber settings
Not cheat to change a 65£ guard 61 AB 5.0 supercharged rocket
07 HSE TDV8 with lots of toys EGR removed BAS remap
56 HSE WAS FULL OF PROBLEMS
Post #533637 Wed Aug 23 2017 10:35pm
RRSNUT
Thanks guys,
I have just come back from a 400 mile round trip and found when I stopped for a break some of the wheels seemed to be radiating heat far more than others and this seemed to change between three wheels.
Not sure if brakes are binding, I think I will need to contact one of the lads, Bodsy or Woody32 to see if they can have a look, I need it sorted out as I intend on purchasing a caravan soon and don't like having issues with Brakes etc
Post #534000 Mon Aug 28 2017 11:56pm
