Home > Maintenance & Modifications > Oil Pump |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4753 |
probably worth having a look at the stickies at the top.
Fri Aug 25 2017 10:49am |
DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240 |
Cheers Andy, yes indeed, I was just trying to sus out all the various part numbers/batch numbers/new upgraded numbers for the 'beefed up' oil pump...
Fri Aug 25 2017 11:05am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4322 |
Wouldnt use anything other than an OEM/Genuine pump... |
Fri Aug 25 2017 12:02pm |
The pump in the link I posted has the FoMo company stamp on it. I thought that meant it was a 'good un' RRS 2.7 HSE Stornoway Grey
Fri Aug 25 2017 12:07pm |
Fri Aug 25 2017 12:10pm |
OK, thanks for the pointer Mikey. It is a bit of a minefield out there for the untrained eye. RRS 2.7 HSE Stornoway Grey
Fri Aug 25 2017 12:21pm |
Anyone know if this would be a genuine Land Rover part as stated on this website:
Mon Aug 28 2017 9:03am |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2006 |
Island are a reputable company and it says its Genuine and the photo shows it in genuine packaging so I'd be ok with it Visitor from fullfatrr.com
Mon Aug 28 2017 9:09am |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1061 |
Why not just go to a LR, Jaguar or Citroen dealer and get one there. 07MY RRS TDV6
Mon Aug 28 2017 9:39am |
Nice one. Thanks DrRob. RRS 2.7 HSE Stornoway Grey P38 4.6 HSE V8 |
Mon Aug 28 2017 9:40am |
Stating the obvious but absolutely spot on. I just called local LR dealer and got most of the parts required for same, if not slightly cheaper than various online places and no worries if they are genuine or not. I'm always under the impression everything is cheaper online and NOT from the main dealer, but not in this case. RRS 2.7 HSE Stornoway Grey P38 4.6 HSE V8 |
Mon Aug 28 2017 10:03am |
Do tell. What are the prices from a LR ?
Mon Aug 28 2017 10:33am |
I thought you put an oil pump on a few months ago anyway? |
Mon Aug 28 2017 10:35am |
priced top of engine stuff from LR... gaskets, bolts etc same as if not cheaper than what you would find on ebay, other online stores. RRS 2.7 HSE Stornoway Grey
Mon Aug 28 2017 10:45am |
