Home > Faults & Fixes > Gearbox fault.
looneyfitter
2005 Range Rover Sport TDV6 HSE Alaska White
Gearbox fault.
Hi after some help please. Had an intermittant F fault come up on the dash every now and then when i put my foot down. Ok when turn engine off then on.
Drove fine apart from that. Anyway purchaced iidtool so reset the box to see if would cure the fault. It didnt, it has gone alot worse. Clunks into gears now, not smooth at sll and kinda lunges forward when stopped. Almost as if its dropping into 1st when stopped. Seems better if i manully do gears. Its a 2005 rrs
Many Thanks. Gareth.
Post #533715 Thu Aug 24 2017 7:33pm
looneyfitter
Also i have re-calibrated the gearbox and clutch. Made no difference. Any ideas?
Post #533716 Thu Aug 24 2017 7:34pm
Any error codes for the gearbox? 2012 SDV6 - it's missing a couple of cylinders
Post #533737 Thu Aug 24 2017 9:33pm
looneyfitter
Nothing at all mate. Works perfect if i use manually. Basically not gearing to 1st untill stopped so shunts a bit. Calobrated clutch. Same.
Post #533900 Sun Aug 27 2017 12:23pm
Bodsy
Site Sponsor
Does sound like oil needs changing... has it ever been changed?
Resetting gearbox, will clear the adaptive settings and there is a possibility of it being worse for a period of time. It will adapt itself again over the next few hundred miles. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #533936 Mon Aug 28 2017 9:15am
v8fanatic
I had the same problem with my RRS. I took it to have the gearbox oil flushed. It is now a beast and all the clunking and shuddering has gone. I would recommend a gearbox flush by someone who knows what they are doing. Make sure they use the right oil too.
Post #536475 Tue Sep 26 2017 4:35pm
