Home > Faults & Fixes > Gearbox fault. |
looneyfitter Member Since: 13 May 2012 Location: liverpoool Posts: 212 |
Also i have re-calibrated the gearbox and clutch. Made no difference. Any ideas? |
Thu Aug 24 2017 7:34pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8843 |
Any error codes for the gearbox? 2012 SDV6 - it's missing a couple of cylinders
Thu Aug 24 2017 9:33pm |
Nothing at all mate. Works perfect if i use manually. Basically not gearing to 1st untill stopped so shunts a bit. Calobrated clutch. Same. |
Sun Aug 27 2017 12:23pm |
Does sound like oil needs changing... has it ever been changed?
Mon Aug 28 2017 9:15am |
v8fanatic Member Since: 26 Sep 2017 Location: Chigwell Posts: 3 |
I had the same problem with my RRS. I took it to have the gearbox oil flushed. It is now a beast and all the clunking and shuddering has gone. I would recommend a gearbox flush by someone who knows what they are doing. Make sure they use the right oil too. |
Tue Sep 26 2017 4:35pm |
