Home > General > Advice
Abdool
Advice
Having a look at a 2007 TDV8 HSE tomorrow, any advice you guys can tell what to look for when test driving?
Post #532707 Sun Aug 13 2017 10:19am
Tyrefitter
Check for knocks coming from front end,check suspension works as it should.what mileage as it done as the turbo's are prone for going round the 80k mark.plus what's the history like.
Andy Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #532709 Sun Aug 13 2017 10:50am
geoffsnook
Smoke from exhausts turbos as they suffer from failure due to heat electrics all work full service history any knocking from suspension air con working tyres for wear to start Thumbs Up
Post #532711 Sun Aug 13 2017 10:53am
Paddi
There is a known problem with the differentials around 2007. For some reason it is more often the front that fails - symptoms are a speed related thumping noise on overun from highish speeds and may be evidence of leaks from oil seals.
Check front and rear ARB actuators for fluid leaks. These cost £1500 each plus fitting.
Check gearbox for fluid leaks (view from read over top of the undershield) fluid may be visible on the crossmember.
Check operation of gearbox. Changes should be almost seamless with no harsh lurching. Check for vibration from torque converter when accelerating gently up an incline (indicates TC is in need of replacement).
Don't accept it has full service history without seeing the book. Services are annual/15k miles so should have ten stamps.
Good luck as the TDV8 is a great vehicle but there are a lot of poor neglected potential moneypits out there! Get a good warranty. 2008 MY Java Black TDV8 HSE
Post #532715 Sun Aug 13 2017 12:25pm
Tyrefitter
Ive had 2 tdv8's 1st one was a black 07 kept it about 15 month so it would have been about 4 year old when I px'd it for a 58 plate white tdv8 & the dealer had to spend a fortune on front suspension before they could re sell.To be honest I would NEVER by a car like this without LR warranty.Someone I know bought what they fought was a cheap 08 tdv8 & I said wait till the turbos go,,,,2 weeks later & a big bill from LR to replace turbos,,now it's a expensive RRS.
Andy. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #532717 Sun Aug 13 2017 2:12pm
Abdool
Thanks guys really appreciate the advice, any suggestions for a tracking device as it's a requirement for my insurance? If the Sport looks and drives well I'm so looking forward to owning it. I will lee you posted of the outcome. Once again many thanks.
Post #532752 Sun Aug 13 2017 7:36pm
Tyrefitter
This is the tracker you need
http://www.trackerdirect.co.uk/tracker-cat...205%20Plus
Andy Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #532754 Sun Aug 13 2017 7:43pm
geoffsnook
Ask your insurance what they require as they are asking you to have a tracker fitted so they know which ones they accept as if you fit one and they don't recognise then they will only ask you to fit the one they do Thumbs Up
Post #532756 Sun Aug 13 2017 7:48pm
BKHK
Australia
Abdool
There is tons of advice on this forum. I think you need some more research before buying a 10 year old TDV8. You say if it looks and drives well you will look forward to owning it.
Unless you have some experience with RRS, you might not know if it drives well as you may not have enough points of comparison. Be careful buying a 10 year old RRS (unless it's from a member here where it's likely to have been better cared for)
Post #532779 Sun Aug 13 2017 11:19pm
Johnski
Andy
Quite agree with Andy, I have this model fitted too and got a extra 12% discount on premium (and already have 15 years NCD),
Plenty of models about, many insurance people now want a tracker fitted, the extra you pay for this model is well worth it IMHO. Thumbs Up John
Post #532932 Tue Aug 15 2017 8:43pm
