Home > Technical > Limp mode issues
Rangeboy
Limp mode issues
Hi, New to forum and RRS ownership.
Post #530558 Mon Jul 17 2017 4:14pm
GodivaNige
Doubtful the problem is the fuel rail/sensor. The fault does indicate fuel starvation so as you've fitted a new filter, next investigate for a possible faulty or worn fuel lift pump.
Post #530560 Mon Jul 17 2017 4:29pm
Rangeboy
Thanks. Does that require removal and test or is there a simpler way?
Post #530561 Mon Jul 17 2017 4:33pm
GodivaNige
Seem to recall someone on the forum managed to measure the fuel pump pressure with a gauge to determine a similar issue. Hopefully he'll see this and be able to help.
Is there any misfiring/hesitation prior to going into limp mode? If you can find someone with an IID tool willing to help, I think you may be able to read live values for the fuel rail sensor but it does sound like starvation, as the problem is occurring under load on an incline.
Post #530563 Mon Jul 17 2017 4:43pm
Rangeboy
Thanks.
Post #530564 Mon Jul 17 2017 4:46pm
GodivaNige
Just remembered that you won't be able to tap someone up to help with an IID tool as they have to be registered to the car, unless someone has the Pro version which is usually limited to garages/mechanics.
Rather than guessing and throwing parts at the problem, might be worth having an Indy look at it.
Post #530565 Mon Jul 17 2017 4:56pm
Simon_scott_wilson1979
United Kingdom 2007 Range Rover Sport TDV6 HSE Izmir Blue
Hi. I'm having exactly the same faults and have done the same quick fixes that you have. Thought the fuel filter had solved the issue, but after three weeks of perfect running it's just come back.
Did they lift pump change fix the issue?
Out of interest, the first round of problems I had was P2290 control pressure too low. After the filter change it's now gone to P0087.
Post #531338 Wed Jul 26 2017 7:45pm
RobP
Sounds like a potential diesel injector fault TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten
Post #531561 Fri Jul 28 2017 10:28pm
Rangeboy
I ran some Wynns EGR3 cleaner through it today.........see what happens.
Post #531966 Wed Aug 02 2017 10:10pm
Rangeboy
I've since run some EGR valve cleaner through the air intake and had no more issues. Not saying I've cured it for sure.........
Post #534205 Thu Aug 31 2017 7:44pm
