Home > Technical > Location of front heated windscreen fuses |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4833 |
Adrian,
Wed Jul 26 2017 8:38am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4777 |
Pillars should remove. Maybe it got hot.
Wed Jul 26 2017 9:32am |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 |
The fuses are very stiff, but you can also pop the top off and check for continuity from one half to the other. MY12 RRS HSE
Wed Jul 26 2017 12:37pm |
Bill Portland Member Since: 01 Feb 2017 Location: Dorsetshire Posts: 387 |
Just pulled it out with a bit of a pull and wiggle.
Wed Jul 26 2017 12:48pm |
I'd get the side trim off before you replace the fuse and disconnect the windscreen if easy.
Wed Jul 26 2017 6:10pm |
Halfords only stock the full size ones, not the low profile ones. I've ordered a couple from Rimmer's.
Wed Jul 26 2017 6:25pm |
