Home > Maintenance & Modifications > Front Brembo brake conversion sorted |
tonywolf Member Since: 14 Sep 2015 Location: Devon Posts: 97 |
Very cool, Ive got all the parts less the splash guards, they seem to be like rocking horse Did you fit them? Best Regards
Fri Jun 03 2016 8:42pm |
sean2204 Member Since: 05 Mar 2016 Location: York Posts: 55 |
No I let my local garage do it. They've fitted it with the existing splash guards no problem... |
Fri Jun 03 2016 8:48pm |
Look if only i could get a set of 19s over them! 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Fri Jun 03 2016 8:52pm |
Oh right , i was under the impression that the splash guards were to small for the 380m Discs Best Regards
Fri Jun 03 2016 8:54pm |
They just fit. |
Fri Jun 03 2016 8:58pm |
Allycarson Member Since: 04 Jul 2017 Location: Dumfries Posts: 24 |
is ther a link to the parts needed do the calipers fit strait on I assume these are 6 pots off the current model rrs |
Sat Jul 22 2017 5:50pm |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 389 |
The brakes on my 2010 TDV8 have never inspired confidence and lack low speed modulation. I am still on the original front pads and discs so I have had no need to spend money on brake maintenance. Is it worth changing to the Brembo calipers and discs ie will I see a substantial improvement in braking in my normal driving which is mostly low speed stop start city use. |
Mon Jul 24 2017 12:03pm |
Probably not but looking cool is king😎😎 |
Tue Jul 25 2017 5:01am |
d-9 Member Since: 10 Jan 2017 Location: Herefordshire Posts: 299 |
More aggressive pads are your best option to improve brakes for low speed driving. See if you can buy mintex 1144s for your sport. Caliper rebuild or even just a bleed might also help, depending when they were last bled. |
Tue Jul 25 2017 2:40pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4779 |
brembo's won't be a benefit with town driving |
Tue Jul 25 2017 9:46pm |
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 |
I think I'd have painted the calipers black first, more discreet and won't show the dirt so bad... 13MY Range Rover Sport Autobiography SDV6 - mine
Tue Jul 25 2017 11:02pm |
Just done mine and splash guards won't even look at them
Sun Aug 13 2017 8:55pm |
Ron H Member Since: 13 Aug 2018 Location: Aberdeen Posts: 6 |
Hi, can you let me know where you bought your Brembo calipers? I need front set for my L320 TDV8 HSE Sport
Thu Sep 20 2018 9:26pm |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1847 |
There’s loads on eBay. 2012 5.0 SC AB
Thu Sep 20 2018 10:50pm |
