Home > Faults & Fixes > Sorry another central locking issue from a newbie
Sionr
United Kingdom 2008 Range Rover Sport TDV6 HSE Alaska White
Hi hope I've posted this in the right place I recently purchased a 2008 rrs 2.7 hse with 47k miles
I new it had a few problems ( brakes air compressor and a few bushes ohh and handbrake issue ) but after spending money on it and now yesterday with no warning the central locking stopped
Neither lock or unlock works on the key or the boot button
And if I press the lock on the dash only the rear doors lock and the pass twitches
I know there a common fault door latches but would they both stop at the same time without warning and why doesn't the boot open by fob? I'm ok with mechanical fixes but electrical I'm like a chocolate chainsaw
I'm not a wealthy fella and considering selling if faults keep popping up I thought I'd be ok buying a low mileage one (apparently Ian wrights old rrs)
Any help would be appriciated
Thanks
Post #530742 Wed Jul 19 2017 2:43pm
Eaters
Is the battery healthy?
Overnight charge on trickle Question Question Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #530759 Wed Jul 19 2017 7:45pm
Sionr
Hi thanks for the reply I'll go plug it in now and try that thank you
Post #530762 Wed Jul 19 2017 8:16pm
hard2beat2014
United Kingdom 2005 Range Rover Sport TDV6 HSE Chawton White
cant see why the battery would cause central locking problems
Post #530763 Wed Jul 19 2017 8:22pm
Sionr
I'll try anything before taking it to the dealers
It was stood for a week while I was on holiday but was working when I got back for 5 days so I doubt it's a battery issue but I am far from clever when it comes to electrics
Post #530765 Wed Jul 19 2017 8:29pm
donny dog
Re: Sorry another central locking issue from a newbie
Sionr wrote:
....... and the pass twitches
I think that's just nerves! Laughing
Post #530769 Wed Jul 19 2017 8:50pm
Sionr
Battery recharge didn't work thinking of ordering anew fob battery
Post #530825 Fri Jul 21 2017 8:52am
Eaters
Sorry it didn't work. Hope it was worth a go though. I'm with you; anything to avoid the dealer Robin
Gone:
MGZTT 190 2.5
Post #530826 Fri Jul 21 2017 8:54am
Sionr
Well like I said to the Mrs maybe it's the fob battery knackered and the two front doors never locked I mean I never actually checked if they were locked after pressing the button
And there's nowhere around here to check if it's working so I'll chance buying a new one
Post #530828 Fri Jul 21 2017 9:02am
Socast
:EDIT: Sorry, didn't read properly Embarassed
You can get a key tester off ebay for around £30, or your local garage may have one. I personally don't think it's the key though, there seems to be something fundementally wrong with the whole system. The door lock contorl module may be on the friz.
Post #530831 Fri Jul 21 2017 10:16am
Sionr
The fob isn't doing anything
Post #530832 Fri Jul 21 2017 10:39am
Sionr
If I take the key apart and check the voltage in the battery it will rule out that atleast correct? Or no
Post #530833 Fri Jul 21 2017 10:41am
Sionr
Well I managed to split my fob case without damaging it (poor previous fix by someone) and the battery wasn't connected on one side little temporary solder fix and it's working again
Thanks for the replys guys appriciated
Ohh and might have a lot to do with my 1yr old dropping it a lot
Post #530834 Fri Jul 21 2017 10:55am
Socast
If you open the key you can test the battery yes, but the voltage on the battery doesn't dictate if the key works or not. You will also need to order a new case if you open the key, but before doing that, see if your local garage has a key tester, that will tell you if the key is emiting a signal and takes seconds to do.
Do you only have a single key ? if so I recently bought one of these (as my second key stopped working and the battery was fine) https://tinyurl.com/y6w63nvq
You will need to get a blade cut, not sure if the places on the high street can do it.
Post #530836 Fri Jul 21 2017 10:59am
Sionr
makes sense I do need a spare
Post #530837 Fri Jul 21 2017 11:00am
