Home > Europe > Black smoke. But not the tubo
illbeinthepub
Germany 2007 Range Rover Sport TDV8 HSE Java Black
Hi all. So I have a 2007 rrs v8. The last few weeks it has started to smoke. It only happens when I give it a lot of gas or it has to change down a gear. I told it to the local range rover shop. They checked every thing from the tubo, compression, exhaust. And they said everything is running as normal. The only thing they found was a small crack on the exhaust system (Which to me means they did look hard ). But we're unable to find anything wrong! Have any of you had/hread of this before?
Thanks for the fore coming help..
Post #530460 Sun Jul 16 2017 10:29am
geoffsnook
sounds like intercooler hoses or a split intercooler both quite common Thumbs Up
Post #530472 Sun Jul 16 2017 1:39pm
illbeinthepub
They found some oil in the right hand hose but didnt seem to be so interested by it. Saying it was normal amounts!
Post #530519 Mon Jul 17 2017 5:10am
panda
Would be nice to know about the oil as I have just replaced mine on 2.7 diesel and had oil at bottom of hose as well.
PANDA
Post #530524 Mon Jul 17 2017 6:47am
GodivaNige
England 2009 Range Rover Sport TDV8 HSE Buckingham Blue
Small amounts of oil found in intercooler/turbo hoses is normal
Post #530528 Mon Jul 17 2017 7:51am
panda
Post #530529 Mon Jul 17 2017 8:01am
d-9
Black smoke out the back is unburned fuel, most likely cause is a boost leak. If it was burning oil, you would see bluey/grey smoke
Post #530530 Mon Jul 17 2017 8:06am
Site Copyright © 2005-2018 Futuranet Ltd & Martin Lewis
