Home > Faults & Fixes > Heating & Ventilation system not working - Help!
Sgthomer99
Hi folks I hope someone can advise me what the problem might be with my 2005 RR Sport HSE. Suddenly this morning I have no fan in the cabin for any aircon or heat. I have tried all the knobs without success. All the lights are working in manual or auto but no air is coming out and the fan is dead. It was all working fine yesterday then today nothing. Could it be as simple as a fuse or might it be something more serious? Help pleas!!
Post #529776 Fri Jul 07 2017 7:27pm
DEVON
Fuse number 51 behind glove box , I think it is 10amps Thumbs Up
Post #529782 Fri Jul 07 2017 8:23pm
Sgthomer99
Hi thanks for that advice but I've just checked the fuse and it appears not to have blown. Any other likely causes before I have to seek professional help?
Post #529807 Sat Jul 08 2017 8:17am
DEVON
I'd also check the relays in the engine compartment,
I'm not 100% sure but I think there are two Thumbs Up
Post #529817 Sat Jul 08 2017 9:10am
phillh
United Kingdom 2005 Range Rover Sport TDV6 HSE Zermatt Silver
I had this problem when I first got my RRS. It was a faulty relay in the engine fuse box. There should be a sticker on the box which identifies what each does. Hope this helps.
Post #529818 Sat Jul 08 2017 9:14am
Sgthomer99
Thanks guys, how do I know if the relay is faulty I presume I can't tell just by looking at it. Do I just try and buy one any way from somewhere? Sorry for all the questions!
Post #529824 Sat Jul 08 2017 10:04am
phillh
I swapped it over with another relay of the same rating from the fuse box to check if the fan then worked, I then swapped back when I realised it was defective and ordered another from Land Rover. I think it was less than a fiver
Post #529834 Sat Jul 08 2017 11:40am
Sgthomer99
Hi folks update to issue and thanks for all advice so far. I have swapped fuses in glove box, negative. Found 2 possible relays in engine bay one with a big fan and one with arrows going into car, still negative after swapping them no fan working but lights on ventilation system. Now I'm stuck, will this mean a trip to a garage?
Post #529841 Sat Jul 08 2017 5:25pm
Sgthomer99
Hi folks just a quick update to the problem I had with my interior fan. She went in for a service with my local garage and they identified that a resistor pack in the dashboard had failed. They ordered the parts from Land rover and after fitting it, I was £185 lighter! At least it's fixed and I now have ventilation again!👍
Post #531923 Wed Aug 02 2017 11:43am
Eaters
Thanks for the update. Always good to know the solution. Thumbs Up Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #531956 Wed Aug 02 2017 5:36pm
