Home > Faults & Fixes > Normal height only!
GARYF123
Normal height only!
Hi, my 2007 2.7 RRS has been getting the dreaded 'bong warning' and yellow suspension light on with message 'normal height only'.
It has happened twice since Friday. If i turn engine off then start again it disappears, Only to eventually return.
I read the replacement end cap fix where the cap is cracked between the 2 collets and expected it to be this. But, I have only had the car a few weeks and i have a receipt for a new LR061663 AMK compressor, air tank, actuator and reprogram of ECU software from August 2015 (£1030.73!).
Has anybody any idea where i should start to look? The compressor has, i think got a limited 2 year warranty but does stipulate that warranty is void if air struts and i think it said bags? are not replaced.
Regards,
Gary.
Post #528426 Sun Jun 18 2017 11:52pm
geoffsnook
If you bought it from a garage take it back to them if you did not it from a garage find out what codes it has got Thumbs Up
Post #528435 Mon Jun 19 2017 7:27am
GARYF123
Hi Geoff, did as you suggested:
C1A20 State 64
Pressure increases too slowly when filling reservoir.
Any suggestions?
Gary.
Post #528507 Mon Jun 19 2017 9:44pm
geoffsnook
check the cylinder for any leaks with soapy water Thumbs Up
Post #528563 Tue Jun 20 2017 2:08pm
GARYF123
Ok, took cover off and sprayed everywhere with leak detector. Nothing!
Sprayed all tank, nothing!
How long is compressor supposed to run for?
Gary.
Post #528578 Tue Jun 20 2017 5:07pm
geoffsnook
Not long really if you put it up to off road height as soon as it's reached it in theory the compressor should then turn off and it should be the same from access height to normal and it will come on every now and then but after start up it stays on for a a few mins then there could be an air leak somewhere Thumbs Up
Post #528583 Tue Jun 20 2017 5:22pm
geoffsnook
Or the compressor is no good
Post #528584 Tue Jun 20 2017 5:23pm
geoffsnook
Have a look here lot more info
http://www.disco3.co.uk/forum/topic102168.html
Post #528586 Tue Jun 20 2017 5:31pm
rostan242@gmail.com
I have a very similar problem After a few minutes shows me Normal height only.I suspect the compressor needs repair.I know I can fix it myself.
I only have such a small problem I can not find where in the car it is fitted, Anyone can recommend some not too expensive Diagnostic tools i have obd2 elm327 But it does not detect any fault codes
Post #531779 Mon Jul 31 2017 6:28pm
geoffsnook
Any warning lights on Thumbs Up
Post #531780 Mon Jul 31 2017 6:40pm
Johnski
As stated all LR genuine parts have a two year warranty, if in doubt get it back to dealer quick as you are running out of warranty. John
Post #531786 Mon Jul 31 2017 7:24pm
rostan242@gmail.com
After a few minutes of starting up shows up warning lights on.And what's worse what happened now
When i start the engine, the car starts to level up strangely,So I tried to change the height a few times,And suddenly stopped to answer and show on screen "suspension will raise when system cooled"
any body can help please
Post #531794 Mon Jul 31 2017 7:58pm
geoffsnook
Sounds like a new compressor is required but without the code not 100% Thumbs Up
Post #531801 Mon Jul 31 2017 8:32pm
rostan242@gmail.com
Compresor I can repair myself I just have to find where it is mounted but I do not have access to a good diagnostic cable
My don't show any fault codes
Post #531803 Mon Jul 31 2017 8:49pm
rostan242@gmail.com
Found errors from the computer
U0126 Lost Communication With Steering Angle Sensor (SAS) Module
c1a20 pressure increases too slowly when filling reservoir
U0421 Invalid data recived from suspension control module
U0132 Lost communication with ride level control module
U0138 Lost communication with all terrain control module
please help me. Is it all related to a damaged compressor?
Post #531824 Tue Aug 01 2017 9:15am
Site Copyright © 2005-2018 Futuranet Ltd & Martin Lewis
