Home > My Range Rover Sport > The "My Range Rover Sport" section
Page 6 of 6 <123456
duncmc
United Kingdom 2005 Range Rover Sport TDV6 HSE Tonga Green
Drove her home yesterday. Very pleased overall even though there are a couple of little niggles. The passenger mirror is broken. It won't fold even though it tries, even after some WD40. And it doesn't adjust well either. And the tailgate bottom button doesn't work well either. So a couple of things to fix.
Then I am going to fit towing electrics and a towbar for our caravan.
Post #475263 Sun Oct 04 2015 3:25pm
Tim in Scotland
Dunc, the upper tailgate is plastic and get condensation between the two skins, also the upper tailgate press rubber cover can perish andlets water into the tailgate so be prepared for more than just a new press button! It sounds like the mirror may have been hit at some time and the casing needs to be reset, IIRC you will find a very very old thread here that has the instructions for the reset procedure for manually folding it to get it re-synched 2018 Melting Silver Mini Countryman PHEV on order for April delivery, bye bye Land Rover after 21 years and 11 LR products..... all because you won’t give me reassurance that should my SDv6 crankshaft break because of a design fault, not MY fault, but the engine builders fault - it will be replaced for free.
2015MY Corris Grey SDv6 HSE Dynamic, but not for much longer........
Post #475272 Sun Oct 04 2015 4:51pm
duncmc
Thanks for that Tim.
I have tried using the search function to find reference to the mirror reset but all they posts seem to relate to the reversing dip and memory seats, which mine doesn't have.
Thanks anyway. I will look through the D3 forum next.
Post #475274 Sun Oct 04 2015 5:27pm
Tim in Scotland
Longshot, try your owner's handbook............ 2018 Melting Silver Mini Countryman PHEV on order for April delivery, bye bye Land Rover after 21 years and 11 LR products..... all because you won’t give me reassurance that should my SDv6 crankshaft break because of a design fault, not MY fault, but the engine builders fault - it will be replaced for free.
Post #475300 Sun Oct 04 2015 8:34pm
duncmc
I think the mirror is actually broken. I did a Google search and found a few references to resynching them by pressing the fold button very quickly twice. All that did was lose the fold function completely.
Others said to remove the fuse to the power fold mirrors for a while. That didn't get the passenger mirror working but it did get the drivers mirror to fold again, and the passenger one to twitch.
The owners handbook was no use I am afraid.
Post #475302 Sun Oct 04 2015 8:49pm
duncmc
I have now finished fitting a genuine tow bar electrics kit. And picked up a second hand barely used detachable swan neck ready to tow the caravan at half term. Long term I will probably fit a fixed towbar, but for now this will do.
Whilst the trim panels were out I noticed that the body is rusting already! Not good.
The car has the Nokia bluetooth accessory module, so at least I can take calls. I am tempted to find the proper PTI kit though and fit that as it is better.
Post #475936 Sat Oct 10 2015 2:13pm
Sinisa
Macedonia 2008 Range Rover Sport TDV6 HSE Alaska White
Post #511308 Thu Dec 01 2016 7:30pm
The_Kilted_Texan
Scotland 2008 Range Rover Sport TDV8 HSE Java Black
Post #522361 Thu Mar 30 2017 7:14pm
geoffsnook
Thats nice and shiney Thumbs Up
Post #522373 Thu Mar 30 2017 7:54pm
The_Kilted_Texan
Thanks a lot. Thumbs Up it recently had to go to body shop after an unfortunate incident but pick it up tomorrow. Then it will be away to get machine polished to bring it back to new!
Post #522477 Fri Mar 31 2017 8:49pm
nah33m
United Kingdom 2008 Range Rover Sport TDV8 HST Java Black
Hi Everyone, i thought i'd put my ride on here to
Post #527379 Thu Jun 01 2017 6:52pm
Fugitive
United Kingdom 2007 Range Rover Sport TDV8 HSE Lux Java Black
New member and hopefully a pic of my sport Thumbs Up
[/b]
Post #547826 Tue Feb 06 2018 6:51am
amgmaj
United Kingdom 2010 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
@Fugitive
Looks nice Thumbs Up
Post #547858 Tue Feb 06 2018 12:37pm
Fugitive
Thanks love the car.. v8 rumble, well for a diesel 😁
Post #547868 Tue Feb 06 2018 1:37pm
Page 6 of 6 <123456
Site Copyright © 2005-2018 Futuranet Ltd & Martin Lewis
