Home > Maintenance & Modifications > LPG |
Ezituper Member Since: 10 Dec 2016 Location: Herts Posts: 71 |
My 90l tank gives me 260 miles |
Mon May 08 2017 6:07pm |
Thanks is that mounted in place of the spare wheel asi only managed to get about 35 liters in mine with about a quater of a tank left in it |
Mon May 08 2017 6:16pm |
Yep
Mon May 08 2017 7:22pm |
ok so i must have a problem as i only managed about 150 miles and only managed to get 35-36 litres in the tank when the gauge said it only had a quarter in it |
Mon May 08 2017 7:35pm |
TheWojtek Member Since: 08 May 2015 Location: PoznaĆ, Poland Posts: 737 |
Perhaps it's because the tank is not fitted horizontally but at an angle and the floating thingy inside the tank doesn't compensate for this. Regards etc.,
Mon May 08 2017 10:41pm |
I can't see how the rank could be fitted any other way
Mon May 08 2017 10:54pm |
ok so perhaps i will see how long the gas lasts and go beyond when the red light comes on as the system has had a new sender according to service history |
Tue May 09 2017 7:14am |
johnunleashed Member Since: 13 Jul 2014 Location: Lancashire Posts: 59 |
don't go off the LPG Gauge they are not good , use your mileage trip . 75lltr I get 248 miles 2007 SUPERCHARGED HST |
Wed May 10 2017 7:13am |
well it is full now with 45 liters of gas so i shall see how far i get i did speak to a lpg guy yesterday and he said he could see a problem straight away as the tank is sat at the same angle as the spare would have been which is about 25/30 degrees anyone no if he is telling the truth |
Wed May 10 2017 12:48pm |
Has anyone got a picture of the rear of there sport with a gas tank mounted so i could possibly see |
Wed May 10 2017 12:52pm |
PaulFireblade Member Since: 27 May 2017 Location: Milton keynes Posts: 19 |
I had an Lpg kit fitted to a previous car:
Mon May 29 2017 11:36am |
Thanks but took advice of local installer and ran it till it started flashing and beeping then filled up and got 80 litres in so now i know my gauge is no good as others have said ignore the gauge and go by miles |
Mon May 29 2017 2:57pm |
Lpg tanks are designed that they will not fill to capacity so a 90 litre tank will not actually hold 90 litres, IIRC something like 80% capacity as Lpg is stored as a gas
Mon May 29 2017 8:55pm |
So I have a 95 litre tank and I got 80 litres in that to
Mon May 29 2017 9:02pm |
