Home > Off Topic > Household sparkys, I need educating
fRRed
Fitting some down lights in a bathroom, the new lights are a 2 wire set up (Just live & neutral.)
The old lights are a 3 wire (earth.)
There are 3 down lights wired in a loop. The new lights are double insulated, so I know they're OK.
My issue is... The last light in the loop currently has only 3 wires to it, easy, connect the live & neutral then terminate the earth and make safe. The other two existing lights though have 6 wires, two of each to make the loop.
Now the live & neutral are easy enough again, just connect both, but what about the two earths?
Do I terminate them still twisted together (do they form part of a bigger loop) or do I separate them and terminate individually?
Many thanks.
Post #527078 Mon May 29 2017 8:07pm
360
United Kingdom 2011 Range Rover Sport SDV6 HSE Buckingham Blue
Join the earth cables together, use earth sleeve and a terminal block
Post #527081 Mon May 29 2017 8:15pm
fRRed
Thanks for the swift reply 360.
Do you mean join just the two existing earth wires that are present at the old connector, and terminate the pair or join ALL the earth wires together and terminate?
Post #527086 Mon May 29 2017 8:27pm
360
Just terminate at each light, this will keep the continuity of the earth so that the cable is earth protected
Post #527088 Mon May 29 2017 8:40pm
fRRed
Much appreciated my friend. Thumbs Up Daily... Audi TT 240 qS, tasteful mods.
Weekend toy... 5' 6", 9 stone, original bodywork!
Post #527089 Mon May 29 2017 8:49pm
Site Copyright © 2005-2018 Futuranet Ltd & Martin Lewis
