Home > Wheels & Tyres > Replace 1 or two? |
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 |
IMO you can stick with replacing one and the same Conti tire. the AWD is not that sensitive RRS 3.0 SDV6 HSE Lux
Thu May 04 2017 5:08pm |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1532 |
I replaced a rear Pirelli with a puncture for a new one. I don't know how many miles the old rears had done but you can see a marked difference in the wear between the new and the old just by looking. I've had no issues with the difference in tread depth between the two rears so I think you'd be really unlucky to pick up an issue.
Thu May 04 2017 9:11pm |
syl Member Since: 10 Mar 2016 Location: Somerset Posts: 411 |
They're around £255 plus fitting (275/40r22) |
Thu May 04 2017 10:09pm |
HemoRRS Member Since: 31 Mar 2016 Location: Wolverhampton Posts: 254 |
Might as well try just the one, should be fine being the same tyre and you'd hope a premium tyre would have relatively tight tolerance control from batch to batch.
Fri May 05 2017 1:46am |
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 527 |
Buy one and use your unused spare on the back and make the part worn one your spare tyre... |
Fri May 05 2017 6:54am |
Unfortunately I don't have a full size spare - its one of those space saver style black wheels 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Fri May 05 2017 8:15am |
Arrrrr.....that won't work then! Just had the same predicament and fortunately I did have! Back to the drawing board! |
Fri May 05 2017 9:02am |
So, is another option to look for a full size wheel (here or on ebay) to use as a spare - if it will fit Then see if you can flog the space saver and tyre.
Fri May 05 2017 9:07am |
I'm happy to have the space saver, it will work on front or rear and this is the first car I have had in 6 years that has had a spare of any kind, the cars in between have had a 'repair' kit. Also with the running wheel/tyres being 22" I'm not sure that a full size spare will fit in the well. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Fri May 05 2017 9:20am |
donny dog Member Since: 23 Nov 2016 Location: yorkshire Posts: 772 |
Tim, I've got a 22" spare wheel in mine. |
Fri May 05 2017 12:16pm |
Spent a morning touring the local tyre specialists and every one of them except one came up with the same comments -
Fri May 05 2017 2:07pm |
