Home > Maintenance & Modifications > When should i change the Cam Belt? |
Yes it is time or mileage which ever is first |
Thu Apr 27 2017 4:14pm |
Moonpig1971 Member Since: 04 Apr 2017 Location: Small Village in Essex Posts: 13 |
It also appears the majority say it should be changed at 7 years rather than 6? Given the mileage i would like to think it will be good until the end of the year? |
Thu Apr 27 2017 4:20pm |
Bill Portland Member Since: 01 Feb 2017 Location: Dorsetshire Posts: 387 |
i think it's due at 7 years or 105k miles whichever is 1st Merc C220 estate Sport AMG
Thu Apr 27 2017 4:22pm |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
Play safe, change it earlier rather than later. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Thu Apr 27 2017 6:11pm |
My manual says change at 7 years or at a stated mileage, which ever comes first. John
Thu Apr 27 2017 6:14pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8843 |
Your profile suggests it's a TDV8. If so, there is no cam belt - it's a chain and doesn't get changed. 2012 SDV6 - it's missing a couple of cylinders
Thu Apr 27 2017 7:30pm |
Never checked his profile, just from description on original post and no mention of V8.
Thu Apr 27 2017 10:03pm |
d-9 Member Since: 10 Jan 2017 Location: Herefordshire Posts: 299 |
I thought the 2010 was the last year they did the tdv8? |
Thu Apr 27 2017 10:46pm |
scousefly Member Since: 25 Jan 2015 Location: sheffield Posts: 248 |
So does a 2011 3.0 V6 HSE Dynamic have a cambelt or chain? |
Fri Apr 28 2017 12:09am |
Scousefly, That model does have a Cambelt I'm afraid. John
Fri Apr 28 2017 7:36am |
Good spot indeed, thanks for heads up.. Selected wrong drop down by error.. So a TDV6 so i guess a cam belt will be required at the end of the year |
Fri Apr 28 2017 10:19am |
Yes, TDV6 will need the belts changing. 2012 SDV6 - it's missing a couple of cylinders
Fri Apr 28 2017 5:15pm |
V8 (petrol and diesel) are chain, V6 (2.7 and 3.0) are belts. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Fri Apr 28 2017 5:18pm |
for the replies guys much appreciated
Fri Apr 28 2017 8:17pm |
