Home > In Car Electronics > Radio head unit defective |
rabcnesbit Member Since: 29 Jun 2010 Location: London Posts: 95 |
2.7TDV HSE diesel |
Sun Apr 16 2017 7:05pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4779 |
HSE do have an amp under the seat
Sun Apr 16 2017 7:23pm |
So if it's an hse it should have a harman kardon system in it so it should have a amp under the drivers seat |
Sun Apr 16 2017 7:37pm |
d-9 Member Since: 10 Jan 2017 Location: Herefordshire Posts: 299 |
Yup the main car battery. Try disconnecting it for a few seconds and see if it fixes it, takes less than 30s with the appropriately sized spanner (I got the hang of doing it by the light of my phone at the side of the road when I'd found the radio had packed up again). TBH I wouldnt be too supprised if it needs another battery, the advice from my friendly LR master tech is to replace the battery every couple of years as a matter of course on a sport, maybe less if you mostly do short journeys. Its at least worth checking to see if disconnecting the battery fixes your issue, before you spend £833 on a new radio |
Sun Apr 16 2017 7:56pm |
Yes it has a Harman Kardon system, so I guess it will have amp under the seat. Will search for it. Thank you everybody for your advice and suggestions. I shall check it out this weekend coming and report back. |
Mon Apr 17 2017 3:52pm |
move the seat forward.
Mon Apr 17 2017 5:32pm |
Mani Member Since: 18 Jun 2016 Location: Uxbridge Posts: 298 |
Hi Chaps,
Mon Apr 17 2017 6:23pm |
You need to tell it somehow what slot you want it in |
Mon Apr 17 2017 6:38pm |
Hi Andy do think it's worth trying to remove the fuse for a few Minutes and trying again?
Mon Apr 17 2017 6:45pm |
better off reading the manual on how to insert discs.
Mon Apr 17 2017 7:49pm |
Thanks Andy
Mon Apr 17 2017 7:54pm |
Hi Andy the message I get on the head unit is CD2 Error please Eject, and when I try to Eject it makes a sound but no CD ejects I have even tried the eject all CD's function but still no good! MY08 RR SPORT3.6TD V8 FULLY LOADED, COOLER BOX, GVIF UNIT, PIONEER AVIC-F980DAB HEAD UNIT, RETAINING 4X4 INFO OEM SCREEN AND TS-WX130DA SUB
Mon Apr 17 2017 10:10pm |
Mon Apr 17 2017 10:11pm |
Oh dear |
Mon Apr 17 2017 10:14pm |
