Home > Faults & Fixes > Supercharged misfire/eml with no codes |
Topcat2308 Member Since: 24 Nov 2016 Location: Merseyside Posts: 14 |
2006 RRS S/C. EML comes on (solid amber) every 150 miles or 3 hours of ignition on. No codes. Reset a number of times same issue at similar miles/ time. Changed plugs, coil packs, checked harness with no issues. Seems to have a slight misfire/unevenness at idle but is not noticeable whilst driving. MPG avg is showing around 18-19 but occasionally seems a little down on power for short intermitted periods which is slight but noticeable then regains normal condition and will be fine again. It is frustrating as I have to drive 120 miles each day and have to wait to see if light reappears after each spanner session and reset. I have a solus pro diagnostics and have looked at various data and all looks well with the exception of a raised long term fuel trim on bank 2. I would expect a code from the O2 sensor but not a dickiebird. I am going to change this at the weekend. Has anyone out there had anything similar or any ideas? |
Thu Nov 24 2016 10:33pm |
Orange RRS Member Since: 24 May 2016 Location: Lincolnshire Posts: 89 |
Have you checked the wiring to the charge cooler pump, the factory reversed the pins and the fluid flows the wrong way round the system not cooling the air properly, it's a simple case of reversing the pins in the pump connector. It was a tsb back in the day. Life's too short to drive boring cars !
Fri Dec 16 2016 5:11pm |
The aux pump would throw a reduced performance warning along with massivley restricted performance. |
Mon Dec 19 2016 2:52pm |
CRACKA Member Since: 16 Sep 2014 Location: Hallam Victoria 3803 Posts: 170 |
I have a 2006 RRS S/C and the EML kept coming on amber after travelling for a couple of Miles.
Fri Mar 31 2017 12:14am |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1532 |
Don't you just love these cars? Robin
Fri Mar 31 2017 6:07pm |
