Home > General > 2008 seat movement when ignition on ignition off
sestorious
England 2008 Range Rover Sport Supercharged HST Santorini Black
Hi all, as the title, wen I switch ignition on or of my seat moves. I'm sure it's call called access comfort or something 🤔 Anyway, is there a way of switching it off as it's doing my head in ? I could turn it off in my previous cars but can't figure out how to do it ? I set my seat to where I want it but it keeps moving so I have to reset it ? Thanks all !
Post #522257 Wed Mar 29 2017 5:47pm
Bill Portland
If it's the same as mine, you can access it from the steering wheel right hand control, somewhere in the set up menu.
It should go back to the place you set it though anyway. Merc C220 estate Sport AMG
Alfa GT
Rover 76 V6
Post #522261 Wed Mar 29 2017 6:09pm
turn ignition on
press the button on the end of the indicator stalk until it displays SETTINGS
now use the radio buttons on the steering wheel to cycle thru the options. >> ?
I think the option you want is LAZY entry.
when finish the stalk button saves settings
If you have an electric steering column, switch the knob from AUTO to off,
Post #522267 Wed Mar 29 2017 6:29pm
Eaters
As Andy says. The knob can be found halfway down the steering column on the left had side Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #522308 Wed Mar 29 2017 11:08pm
Strange my MY13 A/B has the same rotary switch on the column as mentioned by Andy, either auto or manual position
Post #522309 Wed Mar 29 2017 11:56pm
Bill Portland
Mine does too but, on mine, that control just affects steering wheel movement, not the seat movement. Merc C220 estate Sport AMG
Alfa GT
Rover 76 V6
Post #522315 Thu Mar 30 2017 9:42am
Not sure then because mine controls the seat as well as column when in the auto position.
Post #522318 Thu Mar 30 2017 10:30am
