Home > General > 2008 seat movement when ignition on ignition off |
Bill Portland Member Since: 01 Feb 2017 Location: Dorsetshire Posts: 387 |
If it's the same as mine, you can access it from the steering wheel right hand control, somewhere in the set up menu.
Wed Mar 29 2017 6:09pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4788 |
turn ignition on
Wed Mar 29 2017 6:29pm |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1532 |
As Andy says. The knob can be found halfway down the steering column on the left had side Robin
Wed Mar 29 2017 11:08pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4843 |
Strange my MY13 A/B has the same rotary switch on the column as mentioned by Andy, either auto or manual position Cheers Col |
Wed Mar 29 2017 11:56pm |
Mine does too but, on mine, that control just affects steering wheel movement, not the seat movement. Merc C220 estate Sport AMG
Thu Mar 30 2017 9:42am |
Not sure then because mine controls the seat as well as column when in the auto position.
Thu Mar 30 2017 10:30am |
