Home > Faults & Fixes > Handbrake/brakes stuck on? |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8827 |
Have you tried reversing the vehicle slightly? 2012 SDV6 - it's missing a couple of cylinders
Wed Feb 22 2017 11:22am |
phillh Member Since: 09 Oct 2016 Location: Hertfordshire Posts: 198 |
I think the handbrake (EPB) operates a drum brake behind the discs and calipers and this can stick due to brake dust.
Wed Feb 22 2017 12:13pm |
N1ckC Member Since: 01 Feb 2015 Location: England Posts: 23 |
Wed Feb 22 2017 12:21pm |
All sorted thanks guys.
Wed Feb 22 2017 5:36pm |
As said above, the EPB operates inside the rear brake disc bell and uses good old fashioned drum / shoes. You'll struggle to clean out mud etc. without stripping it down. If you're leaving it parked on a level surface then you might be better not applying the EPB and just leaving it in park. 2012 SDV6 - it's missing a couple of cylinders
Wed Feb 22 2017 9:16pm |
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 |
Doesn't the handbrake automatically apply after a certain length of time if you switch the engine off? I'm in the shed, I'll be back in the real world in a minute. |
Fri Feb 24 2017 7:31pm |
RRSporter Member Since: 08 Nov 2012 Location: UK Posts: 61 |
Wed Oct 25 2017 9:05pm |
