Home > Faults & Fixes > Grinding noise moving at low speed when cornering?
Hocks172
Hi all, I've got a problem that hopefully someone can help me with?
Intermittently when the steering is turned as I start to move there is a grinding noise coming from the rear wheel area of the car.
It's not there going striaght or at normal speeds only at low speed e.g. Below 20mph and always whilst turning?
Any help would be appreciated.
Sam
Post #515911 Thu Jan 26 2017 3:17pm
JonD-RRS
Rear brakes stuck?
EPB shoes?
Rear hub assembly maybe?
Does it grumble when you steer left and right? That may point to hub assembly
Post #517028 Tue Feb 07 2017 8:49pm
Hocks172
Well it's been into an independent specialist CR Allen, and it's been diagnosed as the e-diff actuator?
I'll update once the work has been done to replace it to see if it was that!
Thanks for your input thou I had already replaced the entire rear braking parts!!! Tesla model 3 long range
BMW f15 X5 m50d SOLD!
Disco 5 HSE Lux SOLD!
Evoque Dynamic Lux. SOLD!
RRS HST Sold!
Other gonners, Disco 3, BMW 525d E60, Jag 2.2d X-Type, Merc E240, Audi A4, Peugeot 306, VW Golf GTI 1.8T mk4,Toyota Hilux, Mazda 323f, Escort 1.3!
Post #517034 Tue Feb 07 2017 9:29pm
JonD-RRS
Thought it was probably too obvious but thought I would give it a go.
How much you been quoted for that then? If you don't make no me asking.
Post #517035 Tue Feb 07 2017 9:33pm
JonD-RRS
Post #517036 Tue Feb 07 2017 9:34pm
Hocks172
Well along with 2 new rear Tyres, 4 wheel alignment, new diff actuator, reprogramming and diff update, new lower arms (front)! Around £1650 +VAT Shocked Big Cry Tesla model 3 long range
RRS HST Sold!
Post #517039 Tue Feb 07 2017 10:04pm
JonD-RRS
Ouch!!!!!!
I knew before I bought mine that maintenance costs are high, but there are some horror stories on here.
I had a discovery 2 td5. I had that in pieces most weekends and me in tears.
Love the car so will have to just either fix it myself or pay the big bills.
Post #517041 Tue Feb 07 2017 10:19pm
Hocks172
Well thought I'd give a little update, got the car back Monday and all seems well! Very well which is a great relief as spending that much on it has hurt but on the grand scale most of the works were expected maintenance items so as long as she's driving well it all good!! Tesla model 3 long range
RRS HST Sold!
Post #518229 Sun Feb 19 2017 3:17pm
JonD-RRS
glad its all sorted.
Post #518492 Tue Feb 21 2017 3:58pm
Hocks172
Thanks Thumbs Up Tesla model 3 long range
RRS HST Sold!
Post #518511 Tue Feb 21 2017 7:52pm
NTBeyond
Australia 2010 Range Rover Sport 3.0 TDV6 S Zermatt Silver
Re: Grinding noise moving at low speed when cornering?
Sam
I had a similar problem. The dealer said it was a Transfer Case oil degredation problem.
They checked TSB and found fault #LTB00906V6
They fixed the issue under warranty.
Cheers 2014 SDV6 HSE, Panoramic Roof, 825w sound, Surround Cameras
Gone: MY10, TDV6 Sport, Zermatt Silver, Sunroof, 18" Rally alloys.
2006 Pajero Exceed, Silver
Post #519560 Thu Mar 02 2017 7:57am
Chrisb1985
United Kingdom 2010 Range Rover Sport Supercharged HSE Alaska White
I have a similar issue with mine it’s not just at low speeds but it’s mainly when turning left. Range Rover thought it’s was the arc bars but they have fitted new ones and has not solved the issue. Iam hoping what you had is the same. Has the the work you had done still fixed the issue. For some reason when the stability control failed on mine the noise disappeared that’s why they thought it was the arc bars.
Post #536812 Sun Oct 01 2017 8:49am
