Home > Faults & Fixes > Help |
Lunar_Lamp Member Since: 14 Jan 2017 Location: UK Posts: 9 |
Did you ever find the solution to this? Same thing has just happened to me...
Sat Jan 28 2017 12:18am |
Just to update, in case anyone comes across this via Google, like I did:
Sat Jan 28 2017 2:46pm |
Ozziev1980 Member Since: 12 Feb 2014 Location: London Posts: 15 |
Done |
Wed Feb 01 2017 11:32am |
SMART stands for "Self-Monitoring, Analysis and Reporting Technology", and is a standard feature of modern (and not-so-modern) hard drives. It's found in just about every hard drive around nowadays and in short it's a technology that allows you to monitor the health and performance of a physical hard drive. You could quite happily run a "SMART health check" on your own computer. I'm a tech bloke so saw the test and knew that I understood what it did and could interpret the results - turns out I should have had a little less trust in the software
Wed Feb 01 2017 11:39am |
