Home > Off Roading & Green Laning > Only two wheels on the ground ? |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8834 |
If the vehicle is grounded and wheel spin is detected, the suspension will be automatically raised by approx 50mm to try to give ground clearance. If it's still grounded you can put your foot on the brake and press and hold the raise button for a few seconds. This will give you another 25mm maximum if available. If that doesn't get the chassis off the ground then you will need recovering by another vehicle.
Thu Jan 19 2017 10:32am |
Rolo Member Since: 29 Feb 2016 Location: Manchester South Posts: 47 |
Thanks for that.
Thu Jan 19 2017 11:29am |
Lonescout Member Since: 30 Aug 2016 Location: UK Posts: 35 |
It might be a Land Rover (Range Rover) but it still must obey the laws of physics. I've had to recover too many Land Rovers who's owners mistook them for magic carpets. |
Thu Jan 19 2017 12:09pm |
It might be possible to drag the back end until the rear tyres make contact with ground. However, if the vehicle is sat on its chassis frame (or fuel tank more likely), it's likely that the front wheels would slip and spin. In rock crawl mode you'd have a fully locked centre diff but you'd still be relying on the front tyres to find some grip. No grip, no go.
Thu Jan 19 2017 12:45pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2007 |
He'd have done a lot better without that idiot getting in the way....psychologically it would be causing him to lift the throttle off to avoid running into him. A steady throttle all the way would have done it. Never used a spotter in 30 years... Visitor from fullfatrr.com
Thu Jan 19 2017 1:00pm |
2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black 2013 SDV6 HSE Black Edition- Orkney Grey with Ebony & Ivory. LR Facelift RAI, Genuine G4 Expedition Rack, 4x Warn SBD-160 Spotlights, Warn 9.5XPS Winch, Mantec Underbody Protection and Sump Guard, Full Easy Lift Suspension Module, LR Light Guards, Light Force HTX230 Hybrid spotlights, 18” Compomotive PD1881 on 265/65/18 BF Goodrich KO2, ARB fridge, TuffTrek awning 😎 |
Thu Jan 19 2017 2:26pm |
One wonders why Rolo is asking this -is he thinking of driving off Beachy Head and changing his mind halfway over the edge? Surely RRS ownership isn't so much of a millstone that he wants to end it all! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thu Jan 19 2017 4:11pm |
d-9 Member Since: 10 Jan 2017 Location: Herefordshire Posts: 299 |
Usually when you have wheels off the ground, its diagonally or one corner, which the sport should deal with.
Thu Jan 19 2017 4:47pm |
That is the "cross axle" situation, which any modern Land Rover product with traction control shouldn't find difficult to get out of but in the TDi Defenders and Series Land Rovers could be a problem. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thu Jan 19 2017 5:07pm |
Yep, cross axle generally not a problem for the RRS so long as constant gentle throttle used. 2012 SDV6 - it's missing a couple of cylinders
Thu Jan 19 2017 6:26pm |
It was last September when I reversed over the edge of this sunken vineyard by mistake. I wrote about it at the time on a separate thread but at the time was more concerned with how close I came to flipping the vehicle as I reversed down that slope. The vines are about 4 feet high, so I estimate that the grass bank was 10 feet. You can see the gouge I left in the grass on the left hand edge nearest the camera. In the process of reversing down, I ripped off the front bumper and filled the exhaust cowls solid with grass and soil. So I'd been pretty near vertical. The reason I've opened this thread is that I've not really learned how I'd tackle a similar situation in future if I was unfortunate to loose wheel contact again. Not something I have any desire to repeat, I can honestly add. However, with mountain roads and snow, it's something I'd like knowledge of. It appears that reversing was my only option, I've been wondering ever since, especially when getting panic attacks 😂, whether a drive mode option would have enabled me to simply drive off. Fortunately, I've no experience of near side wheels being off the ground, but I can imagine that this could being a more frequent problem. One sees deep concrete/paved flood channels at the side of some mountain roads, but they wouldn't be obvious when filled with snow. I travel alone and in mountainous regions, or coastal regions where mobile phone cover isn't always good. I'm not an off-roader, but I'll drive on a well marked stone track, or across a coastal headland to wild camp, or photograph an estuary etc. Thanks for your responses. |
Sat Jan 21 2017 2:11pm |
Sorry, cant upload image. However, there's two photos in the gallery that show the situation.
Sat Jan 21 2017 2:14pm |
Seriously, if I were you I'd look at doing some sort of off road driving course. You would learn what a 4x4 is actually capable of (you'd be surprised) and as a bonus what you are capable of. No amount of internet knowledge will substitute for actual hands on experience. |
Sun Jan 22 2017 9:57am |
nigethecat Member Since: 22 Sep 2016 Location: Aberdeenshire Posts: 115 |
Nice photos, didn't know that Manchester was so scenic ! And vineyards !!!! who says Global Warming is a myth |
Sun Jan 22 2017 10:34am |
