Home > General > RRS 2005 STEERING GONE STIFF - HELP REQUIRED
Harry HST
United Kingdom 2005 Range Rover Sport 4.4 V8 HSE Java Black
Hoping someone can help, I've seen a few posts online and need guidance to try solve this issue..
I have a RRS 2005 4.4V8 and the steering has decided to go stiff all of a sudden.
Before I consider changing the power steering pump I need to know if there's anything further I can do to ensure that it is the pump.
I came across the following link if another guy who had the same issue and if appeared to be a half shaft that required to be replaced and solved the issue.
I'm in the Birmingham area and any assistance would be appreciated.
Post #514747 Mon Jan 16 2017 11:42pm
shakeapaw
Try the steering column knuckle joint, they seize on older vehicles, I had mine replaced last year, they cost about £100 plus labour.
They look like this http://www.ebay.co.uk/itm/RANGE-ROVER-SPOR...SwImRYFGnW 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #514877 Wed Jan 18 2017 11:28am
DavidHem
check for leaks where the in and out pipes are bolted to steering rack, you can see them by turning the steering wheel fully clockwise and look from the drivers side wheel, it is common for one or both of the seals to go leading to a slow leak, they are very very easy to change and cost less than £4.00 from a main dealer.
Link to my post on D3 about my D4 leak. The garage told me I needed a new steering rack!!
http://www.disco3.co.uk/forum/topic116960-15.html
Post #514904 Wed Jan 18 2017 2:02pm
Harry HST
Issue found it is the UJ Joint.
Any ideas where I can get one from fairly quickly locally?
Post #515070 Thu Jan 19 2017 2:13pm
shakeapaw
My indie sourced one in an hour, delivered to his workshop, There must be one in Birmingham 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #515075 Thu Jan 19 2017 2:29pm
Harry HST
Not an item Land Rover stock however deliver within 24 hours.
Managed to get genuine part from a local specialist, getting fitted now fingers crossed.
Post #515092 Thu Jan 19 2017 4:23pm
shakeapaw
Thats what I meant, an indie, a local specialist 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #515093 Thu Jan 19 2017 4:29pm
Harry HST
Problem solved steering perfect
Thank you guys Smile
Post #515121 Thu Jan 19 2017 9:26pm
