Home > Faults & Fixes > Slight knock when braking at slow speeds or applying brakes |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
Front lower arm sus bushes. 2008 G4 RRSport TDV8 current
Mon Jan 09 2017 10:06pm |
Rob199026 Member Since: 02 Jan 2017 Location: Essex Posts: 39 |
Oh lovely expensive job ?? |
Mon Jan 09 2017 10:14pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8841 |
Bushes can be replaced but the bolts usually seize so the arms are best just cut off. That means new arms, unfortunately, but is usually cheaper than paying a man to spend hours getting the bolts out.
Mon Jan 09 2017 11:14pm |
Great !! Thanks for help going in for her mot on Monday so will probably fail ! |
Tue Jan 10 2017 8:02am |
Probably won't. The bushes make a noise but still "work" so likely not to be picked up. Fingers crossed, anyway! 2012 SDV6 - it's missing a couple of cylinders
Tue Jan 10 2017 10:21am |
