Home > Faults & Fixes > Suspension Fault Tracing Help Needed |
There isn't much in the workshop manual about pressure but there is this;
Mon Dec 05 2016 6:14pm |
JS3 Member Since: 26 Nov 2013 Location: Yorkshire Posts: 24 |
Thanks Paddi - thats a great help.
Mon Dec 05 2016 9:41pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4321 |
This suggests to me that the compressor is shafted A healthy Hitachi/Dunlop compressor should be able to raise the car from access height to normal, and refill an empt air tank to 18 bar without cutting off at 130degrees, just! A healthy AMK will also do the same, but temperatures will be much lower |
Mon Dec 05 2016 9:48pm |
Thanks Mikey. Even though I repaired the compressor?
Mon Dec 05 2016 9:59pm |
If the compressor gets hot in a short space of time, its generally a faulty compressor.
Mon Dec 05 2016 10:36pm |
Thanks Mikey - when I say heating up, it is the motor unit of the compressor that gets very hot.
Tue Dec 06 2016 2:11pm |
Thanks for the help guys. I have done some investigating into this fault and could not definitively identify a fault within the air system (thanks to Paddi's list) so opted for a new compressor (last item on the list).
Sat Dec 17 2016 7:51pm |
phillh Member Since: 09 Oct 2016 Location: Hertfordshire Posts: 198 |
My son had issues with the pump on his L322 (full fat RR). Its different to the RRS, under the spare wheel in the boot, but the systems are generally pretty similar.
Sat Dec 17 2016 8:54pm |
