Home > Faults & Fixes > Fuel Burning Heater (FBH) |
Hi and Welcome,
Sat Feb 27 2016 8:32pm |
Marcpope Member Since: 24 Mar 2016 Location: Southampton Posts: 4 |
Would you know how to turn the burner off?? |
Sun May 08 2016 1:39am |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
The FBH runs automatically when the outside temp hits 5 or lower and you have more than a quarter of a tank of fuel. If you wanted to stop it working you'd have to pull a fuse or disconnect the connector. 2008 G4 RRSport TDV8 current
Sun May 08 2016 7:26am |
Felloeman Member Since: 12 Dec 2016 Location: Lincolnshire Posts: 2 |
Hi there. I'm new to this site and new to rr. I need to clarify some this about the fbh. Is smoke from the exhaust normal when the heater is working. There is a fare amount, I know it burns diesel to work so i expect there to be some. Stupid question I know but believe it or not I can't seam to find the answer. Is it a case that it needs cleaning? Or is it signs of the beginning of the end and that it will pack up soon? Many thanks |
Mon Dec 12 2016 10:34am |
Smoke from FBH exhaust is normal and can be heavier/ thicker if the system has not fired up in a long time.
Mon Dec 12 2016 10:40am |
Thanks Tim. I'm guessing it's because it hasn't been cold enough up to now. That's a huge weight of my mind with Xmas round the corner. And just paying out for tyres, discs and pads 😨, luckily I'm a hands on person. I have seen a lot of talk about converting it, I might have a look at doing ready for next year. Thanks again |
Mon Dec 12 2016 11:46am |
The 7 day timed version is purely a software upgrade, if you want it with remote control then that is the "full monty" job requiring a receiver unit and remote controller. Both can be done by forum member Bodsy who has a travelling/ mobile service or you can meet him somewhere. He would also advise if the job can be a DIY job. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Mon Dec 12 2016 11:55am |
