Home > General > Does anyone else get a driveline shunt at low speeds?SORTED!
Page 5 of 5 <12345
Disco_Mikey
Mine has this shunt too Rolling Eyes
So far, it has had replaced (because it was all needing it, not just to cure the shunt...)
All 8 suspension arms
All hub bushes/ARB links + bushes
New gearbox and TC
New transfer box
Rebuilt front diff
New rear propshaft
Next part to be attacked is the rear diff. Has a nasty whine now, and metallic fragments in the oil/drain plug
Big Cry
Post #483422 Mon Dec 28 2015 8:36pm
shawnmarsh2015
Same thing happens with my RRS at low Speed. Forecasting Services
Post #483455 Tue Dec 29 2015 12:34pm
Rangie78
Yeah I'm under the impression that the double flush is seen as the most efficient/effective way of clearing the gearbox ready for the new lubricant.
As soon as I mentioned the shunt symptoms to the guy in the garage he said he was 99% sure that the double flush would clear the problem. I would strongly recommend this to anyone with these symptoms.
Post #483654 Thu Dec 31 2015 5:35pm
Byreman
England 2008 Range Rover Sport TDV6 HSE Siberian Silver
Hello Everyone,
I finally got my RRS 2009 HSE sorted with this drive-line shunt - It eventually annoyed me enough to get it done.
1st we looked at the universal joint between the prop-shafts and that was fine. Cover plate off and an inspection by my local garage said all OK - Thats was at no cost.....
I then asked the RR Specialist (not main dealer as they are complete spanners) to do this double flush operation and after having the car back for 3 days I can say that its 90% better than it was. I'm not sure its 100% cured but you really have to try hard to get it to shunt now which I'm happy with.
Cost was circa �360 inc VAT but it involved filters / oil and other bits so all in all quite acceptable. I hope this helps everyone who has this annoying issue that Land Rover claim to be completely normal. It isn't and can be cured.....
This only lasted for a while and the thud came back ! Grrrr
Post #509579 Tue Nov 08 2016 11:07am
Vw1200
Bosnia Herzegovina 2010 Range Rover Sport 3.0 TDV6 HSE Bourneville
Hello,
I am old/new here Smile
Owner of RRS 2010 HSE, 111 000 KM on the clock
Having same problem as You all have and that is knocking, clunking, drive line shunt...etc.
Car is phenomenal, but this issue is not present even in 30 Years old Toyota wit 500 000 on clock, so it is ruining drive feel of the car.
Bought car at 79 000 Km, did not have shunt problem.
around 90 000 km problem appeared and since than, i am in constant search for cure.
What i have done to my car, to find solution,
rear centre prop shaft replaced,
Gearbox flushed
I have replaced transfer box for another, just to open mine and to see chain (hv098) and to see is it stretched.
I am now driving on other Transfer box (135 000 ) on clock, i have same issue.
I am thinking, this could be same issue as mine TC box, so
I have ordered chain, since mine has gap/movement in links.
For me, nothing too much, but each link pin has movement at least 1mm, so it seems a lot if calculated like that.
I want to exclude chain from story, so if problem not sorted, than to continue with front axle,
i will remove front centre prop shaft and try to drive, just to see if problem is present.
if problem still present, (front diff and driveshaft will be excluded from future searching, because i believe if problem still present, than it is not problem, since it is detached from transfer box)
Than, only thing is left is rear diff (mechanics said it is ok and it is not the problem, but i do not believe anymore Smile )
and automatic transmission.
Hope we will all resolve this clunk/shunt issue Smile
Post #544297 Fri Dec 29 2017 9:51am
Richythepom
United Kingdom 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Bodsy did a gearbox reset on my '08 RRS when I had the EGR valves sorted which sorted this for me. 2008 RRS HSE Stornoway Grey
Post #547048 Mon Jan 29 2018 4:35pm
abiopete
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Firenze Red
New gearbox and TC
New transfer box
Rebuilt front diff
New rear propshaft
Big Cry
God that's the stuff of nightmares.
Post #596346 Wed Mar 11 2020 11:42am
abiopete
flack wrote:
I am sure there is a software upgrade called anti bump for the v8 gearbox that is supposed to fix this issue
Flack Thumbs Up
Is this something you can do?
Cheers,
Pete. L494 3.0L SDV6 Autobiography in Chile Red (Current)
L320 3.0L SDV6 Autobiography in Baltic Blue (RIP 29/03/2021 insurance total loss)
Post #599744 Fri Jun 05 2020 4:20pm
keano40
United Kingdom 2013 Range Rover Sport SDV6 HSE Santorini Black
I've a mate with the same, he's replaced loads and next to attack is rear diff too....nightmare!
Post #605620 Fri Oct 16 2020 8:55am
Richie h
United Kingdom 2008 Range Rover Sport TDV8 HSE Siberian Silver
mine does both the shunt and the seat thing! id be interested to see what the cause of it is, i've been told that there could be excess wear in the gearbox, and that it would need replacing, had the gearbox double flushed around a year ago with no noticeable change!
Post #608163 Mon Jan 04 2021 10:00pm
Dave-t
The trouble is the flush doesn’t “fix” wear, it should be used preventively. Joined the X5 45e club
1994 Defender 90 300 tdi
Post #608168 Tue Jan 05 2021 8:23am
Page 5 of 5 <12345
