Home > Other Site Sponsors > LR remote climate parts - special offer
Page 5 of 7 <1234567>
Wixy2
Hi All,
A quick update so you don't make the same assumption I made, I've learned from Bodsy that the Evoke blipper is different to the one needed for the RRS. ... needless to say, correct blipper is on its way thanks to Bodsy.
Post #508366 Sat Oct 22 2016 8:24pm
Wixy2
Just to finish this one off from my point of view...
New blipper arrived and paired with FBH using the 'remove the fuse' method and now working fine.
So my MY2012 AB had the antenna factory fitted
Post #508999 Mon Oct 31 2016 11:14am
Sumoninja
Newbie q
Embarassed Ok, my first RRS (2 weeks), how do I know if I have this function? 2009 RRS HSE TDV8 Embarassed
Post #509016 Mon Oct 31 2016 2:48pm
Bodsy
Site Sponsor
Depends on what the dash looks like, if you are facelifted, then the screen will have an option on the home screen for Timed Climate or it will have a space where it would be. Post a pic up. Thumbs Up
If yours is not facelifted, then I'm afraid you can't use this kit, but I do another remote that would be suitable. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #509049 Mon Oct 31 2016 10:00pm
Mr Rusty
Scotland 2013 Range Rover Sport SDV6 Autobiography Fuji White
I bought one of these kits from Bodsy and Disco Mikey fitted it. Works great!
One question - perhaps a stupid one!
Is there anyway to control the temperature of the air in the cabin out when the FBH fires?
I sat in the car this morn to check if was working ok and yes warmish air was blowing in from the window vents and in the footwell but it was not enough to warm the cabin sufficiently when outside was 6 degrees. Perhaps if it fired for more than 20 mins it might?
I set the temp on the heater controls to high last night when i turned the car off. Does this make any difference? Does the 'car' know how cold it is outside and therefore how warm to blow from the FBH, or does it take the heater controls into account? Or none of the above!
Thumbs Up 2015 RRS AB SDV6, Fuji White, Ivory
2012 RRS HSE SDV6, Sumatra Black and Ivory
Audi A5, 3.0 TDI, Gone
Audi TT, 3.2 V6, Gone
BMW 5 series tourer, Gone
Post #509214 Thu Nov 03 2016 9:59am
Bodsy
Site Sponsor
Glad it's installed and working. Thumbs Up
To answer your questions
Q. Is there anyway to control the temperature of the air in the cabin out when the FBH fires?
A. No.
A. It takes time to warm the water around the engine/heater it won't be warm straight away. After 20 minutes, the temp measure will usually have moved, but It will never be 'hot' using just the park heater, but it does try to warm the water up to 76degrees C
A. Heater control temperature makes no real difference. The park heater logic will determine the power of the fan and the position of the venting to window or face.
hope that helps.
Ian Bodsys Brake Bible
See it HERE
Post #509281 Thu Nov 03 2016 11:06pm
Eaters
Hi Bodsy. I have a 2008 TDV8. Having scanned through all the stuff on remote FBH I believe you have a kit that could be fitted to my RRS.
1) Is that so?
2) How much are we talking about to supply and install?
3) Are you ever this far south (Sussex)? Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #509386 Sat Nov 05 2016 6:23pm
Bodsy
Site Sponsor
2008 needs a different kit, but yes I can supply /fit no problem. Except I'm not down that far very often.
Rayleigh next Sunday if that helps.....? Bodsys Brake Bible
See it HERE
Post #509388 Sat Nov 05 2016 6:31pm
Eaters
Hmmm. Next Sunday not good I'm afraid. I would be able to travel some way if necessary to meet up.
With the kit you are suggesting, what functionality do I get? How much to install and fit? How long would it take to do? Robin
Gone:
MGZTT 190 2.5
Post #509415 Sun Nov 06 2016 8:15am
Mr Rusty
Thanks Bodsy
Appreciate it. Some mornings it could do with 30 mins preheat up here in Scotland! Thumbs Up
A. No.
hope that helps.
Ian
Post #509529 Mon Nov 07 2016 6:04pm
Jase3983yorkshire
2010 Range Rover Sport TDV8 HSE Santorini Black
Hi bodsy i have emailed you, im wanting this remote kit fitting are you in yorkshire anytime soon?
Post #509554 Mon Nov 07 2016 10:30pm
Bodsy
Site Sponsor
Friday any use?
I've replied to your e-mail earlier. Thumbs Up Rolling Eyes Bodsys Brake Bible
See it HERE
Post #509555 Mon Nov 07 2016 10:40pm
Jase3983yorkshire
Friday is good mate i have emailed you back with my details. Cheers.
Post #509559 Mon Nov 07 2016 11:57pm
TomeeRRS
England 2010 Range Rover Sport 3.0 TDV6 HSE Baltic Blue
Hi Bodsy, I have just started a new thread and just come across this one. Here is the link.
http://www.rrsport.co.uk/forum/topic46168.html?highlight=fbh
I am interested in this kit and wondering if you are in the areas mentioned in my link?
Regards Tom
Post #511139 Wed Nov 30 2016 10:53am
Bodsy
Site Sponsor
I'm everywhere! Laughing
But yes, your area is no problem.
Drop me a message with your address and we'll sort it out.
Flippin' cold out there this morning! Bodsys Brake Bible
See it HERE
Post #511141 Wed Nov 30 2016 11:02am
