Home > Tips & Tricks > Getting shiny black tyres?
Page 3 of 3 <123
Nowaytk
Seeing as this thread has had a bit of a resurrection, thought I'd ask the question, I never use the tyre stuff as the way I look at, it is once it's on when you rub the tyre either with a rag or your finger it ends up black, so to me as the product is sort of clear that can only mean rubber is coming off with it? Does the branded "good" stuff not do this and it's just the cheap or what they use in car washes that does this ? 2015 HSE SDV6 Scotia Grey, ebony / lunar, colour coded, deployable steps, TV, sliding pano and a few other bits. Now gone
2018 Velar R-Dynamic HSE sdv6 silicon silver
Post #474232 Fri Sep 25 2015 5:08pm
philmw
United Kingdom 2012 Range Rover Sport Supercharged Sumatra Black
It's the carbon coming out of the tyre (I think).
For the original topic, what I use is Meguiars Hyper Dressing diluted to between 10% and 20%, sprayed on to a cloth, and then that used to wipe the tyre.
Post #474238 Fri Sep 25 2015 5:59pm
Nowaytk
So, do you not need the carbon in the tyre ? 2015 HSE SDV6 Scotia Grey, ebony / lunar, colour coded, deployable steps, TV, sliding pano and a few other bits. Now gone
Post #474240 Fri Sep 25 2015 6:31pm
jeffhunt
Believe tor not, but Swarfega works brilliantly and is a lot cheaper than the branded stuff, especially if you use it at work.
Post #474244 Fri Sep 25 2015 7:07pm
Maks8961
United Kingdom 2006 Range Rover Sport TDV6 SE Stornoway Grey
Hi All,
Being new to the forum your never sure how your posts will be received, however, I've used good old Kiwi black boot polish for years and once buffed up up gives a great finish. Cheaper than most products and your tires will pass inspection.....
Post #503797 Sat Aug 27 2016 12:41pm
capt_steve
Welcome to the forum Maks, good tip. I will give it a go!
Post #503798 Sat Aug 27 2016 12:43pm
Page 3 of 3 <123
Site Copyright © 2005-2018 Futuranet Ltd & Martin Lewis
