Home > General (L494) > Heated door mirror question |
Fletcher Member Since: 28 Jan 2015 Location: Devon Posts: 481 |
How about the movement, are there any signs of life . |
Tue Aug 23 2016 5:21pm |
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 |
Yes, in every other respect, they work fine.
Tue Aug 23 2016 5:41pm |
udash Member Since: 16 Oct 2009 Location: manchester Posts: 196 |
from memory, mirror heaters only work when temperature drops below 5c. |
Wed Aug 24 2016 7:16pm |
That would make sense, although it doesn't help when the dewpoint is well above that. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Wed Aug 24 2016 7:20pm |
I guess the issue would be that not all models have the humidity sensor, and even then its inside the car so may not provide a correct dew point, but now that LR got our idea it might be on MY18 as an 1K option . |
Fri Aug 26 2016 6:23pm |
Correct I believe. A good thing I think, otherwise it would be on a lot of times first thing, a further drain on the battery. John RRS MY12 SDV6 HSE. Sumatra Black/Ebony & Walnut + Dynamic Pack, + Cold Climate Pack + Memory Pack, Digital TV/DVD, Premium Leather, Cornering Lights, Cooler/Fridge Box, & most Options. |
Fri Aug 26 2016 7:15pm |
Autobiography Member Since: 19 Jun 2012 Location: Londres Posts: 328 |
They operate at any temperature when the rear heated screen is on. |
Fri Aug 26 2016 7:52pm |
That is what I thought, but they simply don't. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Fri Aug 26 2016 8:01pm |
Found the info, so turning wipers on can get it to heat even at fairly higher temp.
Sat Aug 27 2016 12:17pm |
Where did you find that? Great info. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Sat Aug 27 2016 3:21pm |
Workshop manual, I took one day access to TOPIX and saved the pages, well worth the effort. |
Sat Aug 27 2016 4:43pm |
Well, this morning, with the ambient at 10C...........they worked. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Tue Aug 30 2016 1:02pm |
