Home > Maintenance & Modifications > Knocking noise and leak! |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8833 |
The oil cooler in the front right bumper/wheel arch has coolant in it, not oil. It's a radiator and helps to cool the oil cooler itself which is down at the bottom of the engine bay. Are you sure the liquid you have found is oil and not just coolant?
Thu Aug 25 2016 8:43pm |
Kizza123 Member Since: 25 Aug 2016 Location: Lincoln Posts: 53 |
At first glance as I am not very mechanically minded I thought it was oil. But as it was going back to the garage to have the knocking noise looked at I thought I would leave it with them to check the leak too. It may be coolant then (hopefully) as it was quite thin stuff but it did seem to leave a oily like patch on the floor? |
Fri Aug 26 2016 8:18am |
Sun Oct 02 2016 10:51am |
