Home > My Range Rover Sport > Reverse Camera and TV Installation |
PhilMid Member Since: 14 Aug 2015 Location: Hull, East Yorkshire Posts: 59 |
Sounds like you may need a GVIF unit. It's a fiddly install but will let you connect 3 or 4 phono plugged cameras to your screen. Have a search on here there is a write up I think
Mon Aug 08 2016 4:07pm |
Mani Member Since: 18 Jun 2016 Location: Uxbridge Posts: 298 |
Hi Pal I was in the same boat as you fitted camera, the only way it is going to work is by a module that is connected to the sat nave under the seat,
Mon Aug 08 2016 5:07pm |
If it's the facelifted 2010, there isn't a satnav under the seat. You will have to remove the full touch screen unit and open it to connect the gvif ribbon cables (I found this out the hard way) |
Mon Aug 08 2016 7:07pm |
