Home > Tips & Tricks > How to replace the front seat base foam |
Slim444 Member Since: 09 Nov 2015 Location: Huntingdon Posts: 200 |
Hi folks,
Sat Mar 05 2016 9:52am |
No messing with airbags or the explosive seat belt tensioner etc, just the four bolts to undo, then unplug the heater element and lift out the base. 4th picture down is all that needs to be removed from the car. So much easier than the X5 where I had to remove the entire seat! |
Sat Mar 05 2016 11:41am |
Mr Rusty Member Since: 17 Jan 2016 Location: Aberdeen Posts: 376 |
Great 'how to' fancy doing this myself!
Sat Mar 05 2016 1:04pm |
Jaggs Member Since: 09 Aug 2015 Location: Leeds Posts: 259 |
Great how to, think ill order a seat element and give it a go, I'm only assuming it's the element as it's the only seat that doesn't warm up and the switch lights up ok Nanocom Evo |
Sat Mar 05 2016 1:39pm |
I'd get a new foam if I were you too- when you pull off the old heater pad, chances are you pull bit of foam off with it, especially on the bolsters! You don't want to be pulling the seat apart twice |
Sat Mar 05 2016 3:00pm |
This is true, do you have the part numbers at all ? Nanocom Evo |
Sat Mar 05 2016 4:19pm |
The cushion for mine is LRLR021399 and the heater element LRLR016246
Sat Mar 05 2016 5:10pm |
Ah just noticed yours is 2011 so I'll double check cheers for the info Nanocom Evo |
Sat Mar 05 2016 6:07pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8798 |
I was going to do this a few weeks ago. I got scared by the hog rings and ended up getting my indie to do it. Only cost £40 labour in the end so not too bad. I had thought about zip ties but feared they would cause problems. Should have used them! Live and learn. 2012 SDV6 - it's missing a couple of cylinders
Sat Mar 05 2016 6:45pm |
Sat Mar 12 2016 3:44pm |
Fantastic, glad to be of service!
Sun Mar 13 2016 9:23am |
Yes burnt a big hole in the bolster and the inner cover of the leather Nanocom Evo |
Sun Mar 13 2016 9:57am |
chopperneil Member Since: 25 Aug 2015 Location: Kent Posts: 55 |
Nice write up, my drivers side bolster is sagging so may well do this myself! |
Mon Mar 14 2016 4:14pm |
Fictivision Member Since: 31 Oct 2015 Location: Molde Posts: 31 |
Where did you buy the foam for the 2007 RRS?Can it be ordered from a webshop somewere? |
Thu Apr 21 2016 8:40pm |
