Home > My Range Rover Sport > Conversion.
Page 7 of 9 <123456789>
ABSport
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
Hi I took the handles from the Autobiography which was in the breakers yard, with everything else lol..........Sadly all handles were scratched. So just replaced covers. External locks operate as I took the door modules with the interior.
Post #470026 Mon Aug 10 2015 4:13pm
imb111
2010 Range Rover Sport TDV8 HSE Java Black
wow very impressive Thumbs Up
Post #470555 Mon Aug 17 2015 5:01pm
merlin1
2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Fantastic
brilliant conversion well done , what did you need to change except the door handles to get the lock/ unlock buttons to work on the outer door handles cheers .
Post #472822 Fri Sep 11 2015 11:32pm
ABSport
Hi as I had removed the interior from a 2012 Autobiography the door cards had the door modules in them, with this I removed the handles and fitted them. I only replaced the external covers as 3 of them were scratched. They are only clipped in on the facelift models Thumbs Up
Post #472843 Sat Sep 12 2015 10:15am
merlin1
ext handles
So the wiring was already there to plug the outer handles into?
Post #473023 Sun Sep 13 2015 6:38pm
ABSport
The wiring from the door handle plugged into each door module.
Post #473039 Sun Sep 13 2015 8:19pm
merlin1
Ok thanks will have a look .
Post #473316 Tue Sep 15 2015 9:37pm
andman
Andorra 2011 Range Rover Sport 3.0 TDV6 HSE Fuji White
Sensational work... amazing result... Great thread .. Thx 2014.5 SDV6 AB Dynamic ... Fuji /Santorini Pan roof and 22's
2013 Porsche Boxster S 3.4
2014 Audi A3 S line Quattro
Post #476848 Sat Oct 17 2015 10:18pm
markryan15
United States 2008 Range Rover Sport Supercharged Alaska White
Do you happen to know if the 2012 turn signal and windshield wiper levers will work on a 2008 RRS?
Post #478731 Wed Nov 04 2015 2:55am
Range_Driver
Sweden 2010 Range Rover Sport 3.0 TDV6 HSE Java Black
Hi ABSPORT,
Do you have the part nr for center consol unit you use.
I was trying to describe this to our main LR here in Sweden but they only find the console with adaptive unit.
Post #479411 Tue Nov 10 2015 10:22pm
Range_Driver
***Update***
I found in bargain Smile
Thanks anyway
Post #479514 Wed Nov 11 2015 9:37pm
ABSport
Update on thread.
New 2012 tailgate fitted.
Found a 2012 Autobiography rear Tailgate ( one piece ) stripped it all down and sent to the body shop for painting Whistle
Post #483878 Sun Jan 03 2016 12:56pm
markryan15
How'd did you wire it to open?
Post #483921 Sun Jan 03 2016 7:59pm
ABSport
Hi it's wired to open the same way as the 2012, the boot release above the number plate still opens the tailgate and also opens via one press on the key fob.
Post #484240 Thu Jan 07 2016 8:41pm
Newstuart
can anyone else see more than the first 4 pictures? Looks great from what I can see but only the first 4 load up for me
Post #488924 Thu Feb 25 2016 5:09pm
