Home > Technical > EPB |
MDP Member Since: 15 Jun 2005 Location: Back in an AUDI Posts: 8598 |
????? I'm lost , what exactly is this Yours confused MDP " WITH MORE EXTRAS THAN A HOLLYWOOD EPIC " |
Fri Nov 04 2005 3:19pm |
Biggles Member Since: 26 May 2005 Location: Preston, Posts: 916 |
If you pull and hold the hand brake while moving (I suggest you try it at a slow speed) you will find the car will do a very very controlled emergency stop for you. As you perform this you will hear the ABS braking system working, which gives of a similar sound to the HDC when it is being used. Its out there somewhere. Second V10 Treg on the drive at the moment. |
Fri Nov 04 2005 3:58pm |
Thanks
Fri Nov 04 2005 4:03pm |
Leading on from this I often wonder how many people with ABS brakes press as hard as possible to stop quickly.
Fri Nov 04 2005 4:09pm |
So it's braking at all four wheels when it does this? Doesn't just jam on the handbrake, I hope?
Fri Nov 04 2005 4:33pm |
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2574 |
At least it's not like the old RR's where the handbrake was straight off the back of the Transfer Box, no WAY you could ever yank that in an emergency.
Sat Nov 05 2005 6:27pm |
Quiet back road, plenty of ice on one side and I had a play with the EPB this afternoon................................ this is a magic piece of kit and soooo clever!
Sat Nov 19 2005 5:42pm |
Tim,
Mon Nov 21 2005 12:23am |
noddy and bigears Member Since: 05 Nov 2005 Location: hants Posts: 116 |
biggles are you sure you should ease of the pedal the main downside to abs is just this thats why manufactrures are changing to eba thou i do stand to be corrected |
Fri Nov 25 2005 8:58pm |
