Home > General > bmw e60 530d to RRS |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
Welcome.
Sun Oct 04 2015 11:56am |
rrsrocknrollstar Member Since: 04 Oct 2015 Location: teesside Posts: 19 |
thanks for the speedy reply.
Sun Oct 04 2015 12:12pm |
It does provide a service announcement which is yearly or every 15k (whichever is sooner). I service mine myself every 10k (~6 months) which I consider to be more adequate in that regard. I also replace my fuel and air filters at every service, unlike the schedule which specifies every 2nd or 3rd service respectively.
Sun Oct 04 2015 12:53pm |
great reply thanks.
Sun Oct 04 2015 1:10pm |
That's good then. You'll find the (plentiful) "How-to" guides are mostly over on DISCO3. Visiting from DISCO3.CO.UK
Sun Oct 04 2015 1:22pm |
Incase you weren't aware RRS L320 (Mk 1) is a Disco3 in a party frock, the current MK2 RRS L494 is based on the current Range Rover. The Mk1 L320 and Disco3 are the same car under the bodywork. There are plenty of used RRS Mk1's out there so buy the one with the most service history that you can find, before buying also check things like wheels are no bigger than 20" (originally RRS TDv6 needed an uprated steering rack to fit wheels more than 19" unless it had the Dynamic Pack or was a Supercharged, after 2007MY all cars got the uprated rack), check that all the toys work (commonsense when buying any used car), check that the Transfer case (RRS has high range and low range gearboxes to enhance offroad use) linkage isn't seized due to lack of use (not difficult or expensive to fix but a sign that the car has not been operated in accordance with LR's recommendations) and check that the air suspension operates through it's full range and that it stays at the higher settings and doesn't squat down of it's own accord (can be a sign of leaks or sensor problems). These are all things you can check on the garage forecourt/ seller's drive but will give a good guide as to how well the car has been looked after. A rare one but one that a friend of mine came across when buying a used RRS, check in the instrument binnacle for any signs that the engine management light hasn't been covered over with black insulating tape........... he experienced three cars that he looked at with that issue before he found one that was warning free!, but I'm sure that also applies to many other makes of car too 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sun Oct 04 2015 1:40pm |
interesting reading about it needing a unrated steering rack on early cars.
Sun Oct 04 2015 3:54pm |
The relevant part of the oil pump can't easily be seen, so unless you get proof that it's been done, it's best just to budget for it. Visiting from DISCO3.CO.UK
Sun Oct 04 2015 5:34pm |
how much is it to replace |
Mon Oct 05 2015 2:11am |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 |
AFAIR it's about 800 pounds if done as God intented, which is with the cambelt replacement at the same time. Regards etc.,
Mon Oct 05 2015 8:52am |
As above, though can probably be had for less, dependant on the garage labour rate, and if you want a genuine-boxed pump ( http://www.disco3.co.uk/forum/topic133955.html ) etc. It's a PITA, but worth it for the piece of mind. Visiting from DISCO3.CO.UK
Mon Oct 05 2015 9:08am |
