Home > Group Buys > IID Tool - Bluetooth - £365 delivered
Disco_Mikey
Currently being run on D3. We have our minimum of 10 units, if anyone on this side is interested
Not huge savings, but better than nothing Thumbs Up
http://disco3.co.uk/forum/topic130337.html
Post #464130 Tue Jun 09 2015 11:38am
Lost for Words
Mikey is running another group buy, same as the last one, if anyone is interested. Thumbs Up
http://www.disco3.co.uk/forum/topic133849.html Visiting from DISCO3.CO.UK
Post #471407 Sun Aug 30 2015 7:58am
Lost for Words
The minimum 10 people required has already been met now, but still room for more. Smile
Thumbs Up Visiting from DISCO3.CO.UK
Post #471519 Mon Aug 31 2015 9:49am
Tyrefitter
What does this IID tool actually do,,I've tried finding details on here but not having much luck.
Andy. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #471530 Mon Aug 31 2015 11:37am
Lost for Words
You can get details of coverage here: http://www.gap-diagnostic.com/products/iidtool.html
For the BT model, the basic functions (fault codes, live data, component control and service routines) are unlocked and available for all covered vehicles. Enhanced functions (CCF editing and ECU flashing, and calibrations like the suspension, transfer box and SAS) are VIN locked. You can buy additional licences (for any covered model) for £60.
The device works best via bluetooth using an app (free - Android and Apple), allowing graphing of live values etc., but can also function on it's own using the instrument cluster to write on like the IID "classic". (NB: Not all Android devices are compatible, so best to check first.)
A couple of screenshots:
Post #471532 Mon Aug 31 2015 12:00pm
Disco_Mikey
A bit more info, for anyone sitting on the fence Wink
Having worked my way through various diagnostic tools over the years (IDS/SDD, Autologic, Faultmate, Haweye, Nanocom etc), the IID Tool beats them all hands down, for ease of use, accessibility, info provided, and above all else, price...
The IID Bluetooth unit is exactly the same as the IIDPro which I use on a daily basis, but is VIN-locked, as explained in the above. The only difference is the Pro version is VIN-Free, and the price.
The IID will perform functions that even JLR's own SDD diagnostic system cannot do, such as Sat Nav on the Move (allows you to enter destination while driving)
It allows FULL Car Configuration File (CCF) editing and allows you to unlock "hidden" features within the car
It allows full software updates (not all models are currently covered, but they are in the pipeline), some of which as required for CCF editing and features to work, such as 3 Flash Indicators.
It allows EAS calibration, either individual corners, front only, rear only, or all 4 corners.
And if it all goes wrong with a calibration, or CCF editing, there is a Restore function, to put it back to standard Thumbs Up
There has been much thought and care put into each, and every process the IID Tool can perform.
They even go as far as forcing failed software updates, and have recovery processes already in place. Most of which goes on in the background automatically, so the end user doesn't have to do anything
I have taken some screenshots with my own Disco 3. There will be differences between the models, and some features available on some that are not there on others.
Fault Code read/Clear
You can also email them to yourself for future reference, or easy copy/paste. The forum software sees 8 + ) together as Cool Whistle
Quote:
VIN: SALLAAA135A336942
Vehicle scanned on 31-08-2015 13:30
Using IIDTool Pro V3.0 B2520
Auxilary Heater
U1A44-6C (2E) Fuel level
Body Control
B1B56-87 (2Cool Sliding roof module - Bus signal/message failure - missing a message
( at 167136 mi )
B1B70-81 (2Cool Local interconnection network bus circuit 2 - Bus signal/message failure - invalid serial data received
( at 166925 mi )
B1C82-14 (2F) Headlamp washer relay coil circuit - General electrical failure - circuit short to ground or open
( at 166900 mi )
B1C90-14 (6C) Auxillary driving lamps relay coil circuit - General electrical failure - circuit short to ground or open
( at 166900 mi )
B1C95-15 (2E) Approach lamps circuit - General electrical failure - circuit short to battery or open
( at 166918 mi )
B1D12-15 (2E) Volumetric alarm power circuit - General electrical failure - circuit short to battery or open
( at 166918 mi )
B1D13-15 (6Cool Interior lamps 1 circuit - General electrical failure - circuit short to battery or open
( at 167117 mi )
B1D14-15 (6Cool Interior lamps 2 circuit - General electrical failure - circuit short to battery or open
( at 167826 mi )
B1D17-87 (2F) Siren Circuit - Bus signal/message failure - missing a message
( at 166900 mi )
B1D18-87 (2F) Volumetric sensor circuit - Bus signal/message failure - missing a message
( at 166918 mi )
Engine TDV6
P0405-00 (2D) Exhaust gas recirculation sensor A - circuit low
P140A-00 (2D) Exhaust gas recirculation sensor C - circuit low
Parking Aid
B1B48-96 (6Cool Rear left outer sensor - Component failure - internal failure
Traffic Message
B1A56-18 (2F) Antenna circuit - General electrical failure - circuit current below threshold
Ventilation
B1B65-15 (6C) Left seat heater temperature sensor - General electrical failure - circuit short to battery or open
B1B66-15 (6C) Right seat heater temperature sensor - General electrical failure - circuit short to battery or open
( at 166904 mi )
B1B75-00 (6Cool Front foot-face mode stepper actuator
( at 167827 mi )
B1B76-00 (6Cool Front left air blend stepper actuator
( at 167827 mi )
B1B77-00 (6Cool Front right air blend stepper actuator
( at 167827 mi )
Height Calibration
Module/Sensor/Height calibrations
Service/Test Menu, offering Key Programming, Service Interval Reset, Aux Heater prime and Operation Check, EPB Unjam function, Lift Pump Security Reset, Suspension valve testing, and Transmission Adaptive Reset
It offers Live Values, both in digital, and graph form
The graphs are invaluable for pinpointing intermittent faults, as you can see the specific rise/fall in readings, instead of the digital values
It offers "Safe" CCF Editing
PatGAPinnov wrote:
Just a few little corrections since Mike does have a Pro and not a BT:
-For safety reasons, access to the full CCF list is available upon request only. However, the tested settings are available to all and these cover 99 % of all requirements.
It also offers "Advanced" editing. For 99% of owners, this option will go unused, but it can be made available for anything you want to retro-fit, or enable. This is where the CCF Restore function is invaluable Bow down
-Re-flash wise, the Pro is capable of housing all supported files while the BT does require either updating the tool to a special firmware for the Nav On Move or using the PC based interface for updating the Bluetooth in any other languages then UK English.
For more details on which re-flash are available and the fast lane service, please have a look at the user manual: http://www.gap-diagnostic.com/support/documents.html
ECU Flash screen. All of these Firmware options are free to use. There is a small charge for Firmware not listed in this menu, and is supplied direct from GAP.
The ECU Info tab allows you to see modules which are fitted to the car and what firmware is currently installed. Invaluable if you are having module communication issues
The Save/Restore tab allows you to save your specified height requirements, and change to them in a matter of seconds, as well as the CCF Restore, just in case Wink
Considering a main dealer will generally charge a minimum of £100 for a diagnostic plug in, the IIDTool offers excellent value for money, and while the saving is not huge, its better than nothing Thumbs Up
Post #471536 Mon Aug 31 2015 1:17pm
Tyrefitter
Looks good but ive got a snap-on modis running 15.2 software which will do most of what I need.
Andy. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #471539 Mon Aug 31 2015 2:16pm
PhilMid
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Bali Blue
Im interested.
How do we go about paying?
Post #471678 Wed Sep 02 2015 3:33am
Lost for Words
Phil, join DISCO3 and get yourself signed up to the group buy. I presume Mike will send out payment instructions once it's ready to go ahead. Thumbs Up Visiting from DISCO3.CO.UK
Post #471749 Wed Sep 02 2015 4:13pm
Lost for Words
Couple more days to go for anyone still thinking about it. Closes on Sunday. Thumbs Up Visiting from DISCO3.CO.UK
Post #471956 Fri Sep 04 2015 10:42am
Lost for Words
Last chance to sign up today, chaps. Thumbs Up Visiting from DISCO3.CO.UK
Post #472184 Sun Sep 06 2015 11:37am
Disco_Mikey
As it stands, we have 17 signed up, so the buy will be going ahead
It will close at midnight, so still a few hours to sign up Thumbs Up
Post #472194 Sun Sep 06 2015 1:04pm
