Home > Technical > Brake Servo failure - PO17 re-occured |
MattMatt Member Since: 14 May 2015 Location: Swindon -ish Posts: 37 |
The RRS I've just bought (from a friend who did pre-warn me there might be a problem) has this oil in the servo failure problem that was subject to a recall some years ago. The car had the recall done in 2009 according to the Stealer and it is going in this afternoon to have it checked out to make certain it is the same symptom
Thu Jul 09 2015 11:34am |
Oil in the Servo. £1000 + VAT to fix it. Gutted. Emailed LR to see if they will foot some of the cost. Not holding out much hope as it's been six years since the recall was done |
Thu Jul 09 2015 3:59pm |
Stuart Member Since: 18 Oct 2013 Location: Manchester Posts: 581 |
Isn't a used servo a better option? Get a 2005-2009 RRS (FAH500210) sat nav/dash mat here - the one that wasn't there when you bought the car.
Thu Jul 09 2015 10:22pm |
Push LR, I would be very surprised if they don't cover this major safety issue. Bodsys Brake Bible
Thu Jul 09 2015 10:50pm |
Thanks for the feedback - I've got a case number from LR now so will see what they say first |
Mon Jul 13 2015 12:26pm |
"a full investigation will have to be undertaken to determine if the concern on your vehicle is indeed related to the P017 recall. If the concern is related then Jaguar Land Rover will liaise with the retailer and cover the cost of repair."
Fri Jul 17 2015 1:50pm |
Hats off JLR and Grange (formerly T H White) near Swindon.
Tue Jul 28 2015 8:37am |
stricko Member Since: 23 Oct 2014 Location: Bexhill on Sea Posts: 35 |
Ive just noticed this on mine over the last few days.
Tue Jul 28 2015 9:46am |
update:
Tue Jul 28 2015 1:57pm |
Hi
Tue Aug 04 2015 2:57pm |
There is no other way for oil to get there, it's their failure to fix it first time..... Bodsys Brake Bible
Tue Aug 04 2015 6:35pm |
Like Bodsy said - the only way oil can get to the servo is through the vacuum pump and up the vacuum tube into the Servo.
Wed Aug 05 2015 9:43am |
Thanks Bodsy and Matt
Wed Aug 05 2015 1:26pm |
Final update - I now have the car back with all new parts courtesy of LR.
Tue Aug 11 2015 10:41am |
