Home > Technical > Remote Fobs not working - both keys start car fine |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
It will be the green splice wire in the passenger side lower sill, a common fault.. do a search on the D3 forum its a well documented fault.
Wed Jul 29 2015 5:37pm |
DC_Supercharged Member Since: 14 Aug 2013 Location: Warwickshire Posts: 27 |
Cheers Flack - I'll have a look. After I lifted the rubber mat up on the passenger side front and rear - I found the carpets were soaked thru with water - so it looks like another problem too. I've got a feeling the sunroof is leaking and the drainage tubes are not channeling water out of the car correctly. |
Thu Jul 30 2015 7:45am |
I have had this on a couple of Sports and Sc RR, it has been the rear tailgate seal that was the cause of the leak. check both pockets at the rear below the lights. if the drians are blocked up then they fill with water and when you brake it all goes rushing forward through to the front, so check this out as well.
Thu Jul 30 2015 12:15pm |
I've poured some water into the front corners of the sunroof channels to test the water flow - and yes the water can be seen leaking into the car from under the glove box on the left by the bonnet release. |
Thu Jul 30 2015 12:22pm |
